Stock Cube Nitrous List
Old Dec 27, 2007 | 10:17 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
More info:
10.008@133.9 - 1.38 - 150shot - 11/18/07 - Pro Stock John - Heads/Cam/Nitrous
Old Dec 27, 2007 | 10:18 AM
LS1Tech Co-Founder
tuff (Michael K) went 9.45@____ about 3 years ago, stock cubes + like 300 shot direct port.
Originally Posted by tuff
I thought big mike went 9.40 and you tied with him.We went 9.45 3 years ago.
Old Dec 27, 2007 | 10:37 AM
LS1SpeedAddict's Avatar
If you feel like updating mine I ran 10.24 on 11/2/07. #7 spot here I come in march
Old Dec 27, 2007 | 11:59 AM
TwistedSS's Avatar
11.75 @ 116.7 - 1.79 - 150 - 11/10/07 - headers/cutout/nitrous M6 - TwistedSS
https://ls1tech.com/forums/showthrea...323&highlight=
Old Dec 27, 2007 | 02:38 PM
BOLO's Avatar
Originally Posted by Ray@Nitrous Outlet
This is compiled form the other thread....If owners will update with complete info I will do my best to keep this updated.
This is the requested Format for info to be updated
10.00 @ 133.9 - 1.38 - 150shot - 11/18/07 - Pro Stock John - Heads/Cam/Nitrous
Classes are
Heads/Cam/Nitrous
Cam/Nitrous
Bolt-ons/Nitrous
- - ET @ MPH - - - 60' - - size shot - Date - Username - Class
1) 9.32 @ 142.8 - X.XX - XXXshot - xx/xx/xx - Smith
2) 9.40 @ 142.x - x.xx - 300shot - xx/xx/xx - Noyze
3) 9.58 @ 138.6 - 1.32 - 150 shot - 06/09/07- Sonic Snake
4) 9.77 @ 135.x - 1.37 - 200shot - xx/xx/xx - BAKED
5) 9.94 @ 133.x - X.XX - 200shot - xx/xx/xx - MOSTDELUXE
6) 9.97 @ 132.6 - 1.44 - 150shot - xx/xx/xx - Charles Cyrus
7) 10.00 @ 133.9 - 1.38 - 150shot - 11/18/07 - Pro Stock John - Heads/Cam/Nitrous
8) 10.24 @ 132.5 - 1.46 - 125shot - 11/2/07 - Ls1speedaddict - Heads/Cam/Nitrous
9) 10.27 @ 131.x - x.xx - xxxshot - xx/xx/xx - WE TODD DID
10) 10.29 @ 130.X - X.XX - 100shot - xx/xx/xx - JaSSon
11) 10.38 @ 127.8 - 1.51 - 150shot - xx/xx/xx - jmill96Z
12) 10.40 @ 129.5 - 1.48 - 150shot - 11/11/2007 - dlove
13) 10.85 @ 128.9 - 1.53 - 200shot - 09/xx/2006 - Robert56 - Bolt-ons/Nitrous
14) 11.08 @ 121.9 - 1.58 - 125shot - 9/28/07 - Z-RATED94 - Heads/Cam/Nitrous LT1
15) 11.42 @ 122.3 - 1.87 - 200shot - 10/xx/2001 - Chris @ NitroDaves.com - Bolt-ons/Nitrous
16) 11.48 @ 127.8 – 1.92 – 125shot – xx/xx/xx – Red Fury - Cam/Nitrous
17) 11.75 @ 116.7 - 1.79 - 150shot - 11/10/07 - TwistedSS - Bolt-ons/Nitrous
Thanks Ray for the "window switch rpm on" advice for my LT1. I'll give that a try when oldman winter leaves. Here is my best and first run on spray ever.
10.441@130.05-1.538-150shot-11/18/07-BOLO-Heads/Cam/N2O
Old Dec 27, 2007 | 03:03 PM
TINKRD's Avatar
dang too bad ya'll aren't doing 1/8 mile. i'd be right there in the 6 or 7 spot... did i mention it was a 6 speed? lol
Old Dec 27, 2007 | 03:15 PM
GM Muscle's Avatar
10.10@135 back in late '05. Just a Cam and about a 225 shot (crank rated). Hopefully I'll be motivated enough to get a better number in the spring.
Oh ya, just checked and I only pulled a 1.48 that pass.
Old Dec 27, 2007 | 05:41 PM
BrianC98Z28's Avatar
10.88@126 - 1.49 - 150shot - 11/06 - BrianC98Z28 - Cam/Nitrous
Old Dec 27, 2007 | 06:22 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
9.45 @143MPH Stock cubes DP 300 shot with 853 casting heads race weight 3250
Old Dec 28, 2007 | 06:14 PM
BAKED's Avatar
Cool, I'm #4, I feel like a "Big Dog" now. At least in the stock cube category.
I would love to get my little motor to run an 8.9999999 My current setup really isn't anything special, it's got a good bottom end but I am running a set of Absolute Speed Stg. 2.5's, LS6 intake, and the factory water pump, I was also blowing through the converter really bad. I was crossing the finish line at 7400 RPM's at 135 mph. That's with 28" tall tires, a glide and 3:55 gears!
Next spring the car should be about 200lbs lighter, and it will have a carb style intake with a plate on top. Also I'm sending the converter off to be tightened up.
On the pass I ran 9.77 I was leaving off the transbrake and I only cut a 1.45 60'. The next pass I flashed it off the line and it cut the 1.37 60' but it popped a little so I let off at about the 330 mark. I still ran a 6.25 in the 1/8th but @ 98 mph opposed to 6.21 @ 112 that I ran on the pass before (9.77). I'm pretty sure if it wouldn't have popped I would have gone at least 9.50 or so but who knows.
Old Dec 28, 2007 | 06:50 PM
jmill96Z's Avatar
Ray, here's the details on mine.
10.38 @ 127.8 - 1.51 - 150shot - 9/3/07 - jmill96Z - Heads/Cam/Nitrous
Thanks
Jeremy
Old Dec 28, 2007 | 07:23 PM
  #32
Robert56's Avatar
Ray, you have mine run listed as bolt-ons/nitrous. It should be bonestock/nitrous. That's what 100% bonestock longblock, not even headers means, lol.
Robert
Old Dec 29, 2007 | 03:52 PM
  #33
Ray@Nitrous Outlet
Guest
Posts: n/a
Robert
Classes are
Heads/Cam/Nitrous
Cam/Nitrous
Bolt-ons/Nitrous
Pick the one that best fits your car
Old Dec 29, 2007 | 06:08 PM
  #34
Josh@KY-Turbo's Avatar
I am building my car now. I hope to be on this list this year.
(Yes I Own a turbo shop, (that not all we do) But I am trying something diffrent while my stock cube Turbo bullet is being built.)
Plan right now is:
-Stock LS1 Short block and 853 heads
-236/240 .579/.579 114+2 Cam
-LS6 intake with a Direct Port 200+ shot
-TH350 w/T-brake
-Moser 12 bolt
-Full Burkhart Suspension
-10pt Cage
The car is getting ready for the body shop now to fix a minor boo boo. Then it diet time. If it doesnt make it faster it is outta there.
Old Dec 29, 2007 | 06:14 PM
  #35
WizeAss's Avatar
if you will post the info in the correct format I will add it to the list....I will add anyone to the list...it is not just top 10.
If we get enough interest I can break it into different groups
Heads/Cam/Nitrous
Cam/Nitrous
Bolt-ons/Nitrous
If you will add this info to the post it will help...if this is not specified I will assume Heads/Cam/Nitrous
Cam/Nitrous
11.44 @ 123 - 1.78 - 125shot - 09/XX/06 - WizeAss
Old Dec 29, 2007 | 06:42 PM
  #36
itsjustaSB's Avatar
11.13@123.2-1.66-100shot-6/22/07-itsjustasb0-cam/spray
Old Dec 29, 2007 | 09:12 PM
  #37
Robert56's Avatar
Classes are
Heads/Cam/Nitrous
Cam/Nitrous
Bolt-ons/Nitrous
Bonestock/Nitrous
OK, Bonestock/Nitrous.
Robert
Old Dec 30, 2007 | 10:27 AM
  #38
Z-RATED94's Avatar
Robert
You had to bolt it in, right? In, on, what's the difference?
Old Dec 30, 2007 | 10:44 PM
  #39
Justa Z's Avatar
9.93 @ 134.x - 1.37 - 175shot - 10/xx/06 - Justa z - Heads/Cam/Nitrous
Old Jan 1, 2008 | 09:02 PM
  #40
MCBRIZ28's Avatar
10.96 @ 122 - 1.54 - 150shot - 3/16/2007 - MCBRIZ28 - cam/nitrous
By Brett Foote | 2026-06-04 05:00:17
