Help with Injectors/Fuel Pump
So using Roberts website I found this formula
(Projected Crank HP x .55) / (8 x .8) = Inj Size
(600 x .55) / 6.4 = 51.5625
So I guess I would need 52lb injectors, and where can I get them? I never have replaced injectors so I don't know what the good/bad brands are.
Also what kind of fuel pump will be needed, and how many gph?
Harris Speed Works Injectors and Pumps
62% IDC with 417 RWHP NA and a 50 shot dry/50 shot wet, for 525 total to the wheels (w/ Delphi 42's).
106% IDC with 300 RWHP NA on a stock motor and 75 dry shot for 363 total to the wheels (w/ Stock 26# injectors).
Lot of guys will tell you to go Green Top Injectors (Ford) and tell you Delphis are hard to tune, I went Delphi's and installed and tuned them myself with EFI live, was not hard at all (first time tuning and swapping injectors), and the car runs great (hot and cold wx in Maine). Matt @ HSW was really helpful with the injector selection and double checked my injector tune tables for me.
Stock fuel pump I sprayed to 466 RWHP (combined 50 shot dry 125 Wet Plate on stock motor) with no issues. Running a Racetronics now (got from Dave and the boys at Nitrous Outlet). Fuel pump is in the drivers side tank. Here is a decent how to for the fuel pump swap:
Cajundudes Fuel Pump How to
Jim
Robert
