dynotune a/f lean shut down switch
Old Dec 31, 2007 | 02:12 PM
jrwireman1960's Avatar
Default dynotune a/f lean shut down switch
I have an 03 corvette, I know you are supposed to hook up the purple wire to an 02 sensor, but which one and what color wire from the sensor? According to the service manual there are 4-02 sensors, does it make any difference which one I use?
Old Dec 31, 2007 | 03:53 PM
d.medic's Avatar
I would think one of the two on the engine side of the cats. Thats only a guess because I dont have this product.
Old Dec 31, 2007 | 05:57 PM
BOTTLE ROCKET's Avatar
JW
I have been trying to get an answer to this question for a week According to the Dynotune rep., you are suppposed to access the O2 isgnal from the PCM, but he didn't know which wire etc. If that's the case, it's going to take longer than the 20 mins. I was told before I purchased the unit.
Some guys are saying that you can just splice into the purple wire on either one of the front two O2 sensors. My only concern was in whether or not it would affect the voltage signal when you spliced it, and what is the prefered method?
Old Dec 31, 2007 | 06:27 PM
Area 51 Racing's Avatar
I don't know about dynotune but autometer told me to hook mine up to the driverside o2 closest to the engine. And yea the purple wire
Old Dec 31, 2007 | 06:35 PM
supersickss's Avatar
i have the same switch and your suppodt to splice the wire into the ( BANK 1 ) o2 sensor witch is the one on your driver side cat, what i did was cit the shroud on the o2 wire then spliced it into the purple wire, when you open the shroud youll see 3 wires, two are tan/brown those are the heater wires and the other is purple ( the sending unit wire) splice into that one.
Old Dec 31, 2007 | 09:45 PM
THE ANSWER - From SSHEETS
You can buy pigtails for that purpose. I think I have the link saved on my laptop...I'll look later. The actual O2 sensor is a sort of a thermocouple which as a junction of specific disimaler metals.
Here they are: http://www.jegs.com/webapp/wcs/store...57617_-1_10625
From what Ive reade, narrowband only tells you if it's rich or lean from the junction's setpoint. I think 450mv is like the setpoint and anything less or more is either rich or lean.
__________________
Old Jan 1, 2008 | 06:07 PM
your link doesnt work, if you look in the direction from the switch yull see that around 800 is were you wanna be
Old Jan 1, 2008 | 06:27 PM
01 Red WS6's Avatar
I think he was trying show a link to item # 182-109049 It's a pigtail to tap into the 02 for a signal. It's only $20
Old Jan 1, 2008 | 07:57 PM
myfast70's Avatar
Do you guys know which sponsors sell Caspers products?
Old Jan 1, 2008 | 08:30 PM
01Z28M6's Avatar
Just go directly to Caspers Electronics. They are a sponsor - near the bottom.
Old Jan 1, 2008 | 08:43 PM
oh ok , wow i wish i woulda known about this, i had a hell of a time saudering under the car lol too late now though
Old Jan 1, 2008 | 08:47 PM
01Z28M6's Avatar
I think this is what he wants: http://www.casperselectronics.com/mm...Category_Code=
Casper's has them for the LT1 flat style too.
