In need of TLC
I have no FPSS
Want to upgrade the 2 solenoids to 1 larger (which to choose?)
Have the 2 smaller hoses running to the airbox still
Have purge, opener, heater
Basically just want to replace the 2 noids for one and rewire everything maybe even add a FPSS if you guys think its necessary.
Ive got 60# injectors, intake walbro and inline.
Will make a N20 only LS1 Edit file for n2o runs.
Im even open to ideas on alternate methods of wiring this up.
EDIT** Meant to add reason for replacing wires/noids is over all this time there is corrosion and a couple wires came off so figgured id do it over.
Thanks
http://www.harrisspeedworks.com/shop...cat=280&page=1
along with some custom hoses and you'll have a sharp looking install:
http://www.harrisspeedworks.com/shop/home.php?cat=261
You mentioned making a N2O only tune, another option, you could run our Interface controller for fueling/timing retard, that way your not pulling timing & running rich NA:
http://www.harrisspeedworks.com/shop...age=1&featured
Let me know if you have any questions.
Thanks,
Matt
