What clutch???
It is going to have a Bob Hanlon prepped Tremec in it. overdrive removed and all the fun stuff, input shaft setup for an LS2.
Car will weigh anywhere from 2800-3200, depending on which class I run.
What clutch should I run?
Engine displacement
nitrous
Fuel
Vehicle weight
Rear end gearing
Transmission type, spline, and gearing
Tire size
Launch and shift RPM
i currently use the RAM 910 VDS system which is a great clutch, but is only rated to 900
