125 shot question
Old Jan 12, 2008 | 09:10 AM
2QUICK4U -WS6's Avatar
well stock timing is at 28 degrees. but if i read right he had a tune put on it when it was stock?? Then if so then the timing was probably advance two degrees depending on the bolt ons and so on. Yes i would pull some timing if that was the case 3-4 degrees on the 125 shot, but only if the timing was advanced. People do run stock timing on nitrous cars up to 150, but play it safe!!!
