Anyone have some NANO install Pictures
#123
Yea, Mine is in the mail as well and I hope it ain't too expensive. I mean, at $2.50/lbs N2O it better not be more than $4-5 or it won't "pay for itself".
#124
Opened my box
Planning day today
Assuming you open the NANO bottle valve and it is auto regulated to 1000 PSI? or do you have to tweak the NANO bottle valve (its a needle valve I think) to set the NANO pressure?
Planning day today
#127
I have a vert, so I'd like to keep the little trunk space that I have.
I think I could fit the NANO bottle on the drivers side wheel well and I know I can fit a 10lb nitrous bottle in the passenger wheel well, so...
Could I run longer lines under the carpet from the NANO on one side to the nitrous on the other side?
#131
I will have pics mid week. I am using the NANO provided brackets and having them Machined to bolt on the Dynotune Billet Bottle bracket (about 2 o clock high on the passenger side).
#132
a 10lb bottle fits perfectly hidden behind the speaker panel where the spare tire goes. adding a nano is going to take up more space and height. i dont want to put the bottle and nano anywhere visible so i want to make sure they both will fit behind that pannel.
#135
10 lb setup
100+ c.i Bottle...4500 max psi w reg.... hpa /h.o. bottle= 850+ discharge psi.. few hundred maybe new from paintball source
inline check valve + -3 or -4 line. less that 50 bucks
Drill and tap bottle valve to accept -3 or -4 line or buy one with a gauge port.. like NX high flow..
fill bottles. connect the two ..turn reg up to 1000psi-1100psi
..testing mine this weekend.. ill post results from dyno and the track
