MSD Window Switch
Old Jan 12, 2008 | 08:32 PM
Z28Caves60's Avatar
Default MSD Window Switch
I was wondering is it true for an LS1 that you have to have the MSD window switch set on 4-cylinder mode
Old Jan 12, 2008 | 08:40 PM
jmill96Z's Avatar
It is true. It took me about an hour to figure out why mine was reading off, then I switched it and it's perfect----we're talking about the digital right?
Old Jan 12, 2008 | 09:07 PM
Z28Caves60's Avatar
No i got the regular switch it has two loops you can cut for 8cyl 6cyl 4cyl
Old Jan 12, 2008 | 09:13 PM
getthesand0ut's Avatar
the digital is 4 for sure but i think they both are.
Old Jan 14, 2008 | 12:00 AM
Nitro Dave's Nitrous Outlet's Avatar
If you have the MSD that takes pills and has not been modified for the LS1 yes you will cut both loop wires.
Dave
Old Mar 16, 2008 | 08:21 PM
jcolews6's Avatar
I was just searching this exact same thing. I had to alter my shift light the same way. Thanks Nitro Dave. While I have you here I need an adapter for the fuel test port for my fuel pressure guage and 4an nitrous line. Do you have this? Thanks
