question about gear lock out
Robert
What trans do you have? If its an auto and you want to try and keep it together for a little longer, you can set your window switch to not spray through the gears.
99 FRC
Dave
I have stage 1 set to be active with a 12-volt input on it's #2 input, and stage 2 to be turned off. Stage 1 is setup with a 1st gear lockout.
I have stage 2 set to be active with no 12-volt input, and stage 1 to be turned off. Stage 2 has NO 1st gear lockout.
This means, I have an extra switch on my Nitrous Outlet panel. I flip it on and it sends 12v to input 2, and turns ON Stage 1 and OFF Stage 2. If I don't turn it on, it sends nothing. This turns ON Stage 2 and OFF Stage 1.
Essentially, I'm turning on/off the 1st gear lockout with the switch. I have not read about anyone doing this, and only dreamed it up after reading about the 2 stages and what the inputs do on the controller. I'll be making a full writeup on my system when my few new parts come in from Nitrous Outlet.
