question about purge...
Old Jan 13, 2008 | 03:04 PM
99FormulaM6's Avatar
Default question about purge...
I have a ZEX purge kit that came with the car...and shouldnt one end of this be flared? how is this going to stay connected to the solenoid??
Old Jan 13, 2008 | 03:59 PM
jmill96Z's Avatar
Most people will ditch that tube and go with a flexible line from a hardware store. There should be a compression fitting on that though. Just a little barrel that goes on the line, under the nut
Old Jan 13, 2008 | 04:15 PM
the fitting is there...but even when i tightened it down (hand tight) it didnt seem like it would hold the line..
what size line should i get at the hardware store?
Old Jan 13, 2008 | 05:51 PM
Nick@HSW's Avatar
Are you using the ferrule? Its a small brass ring that slides on the tube and both ends have a taper sort of forming a spherical-trapazoidal shape. You need that in order to make a compression seal holding the tube in.
Nick
