explain NXL to me
is there a nitrous rail too? so 2 rails on each side? whats the max it can spray(on a built motor)?
i understand there are some cool controls coming out also, like something to do with a wideband, i have the fjo set up. i am wondering if it uses the wide band only as a safety backup or if it actualy activly tunes for you?
any info would be great.
Not sure on the WB and controller, but the new controller is nice, cool little gadget. Progressively time your delivery via RPM, Time or a new Gear mode. small, and can be programmed with a PDA.
Search for NXL in this section, go back as far as 6months and you should see all the discussion on it.
Charlie.
