Running extremely rich and already burnt plugs twice!
Old 07-04-2003, 04:22 PM
SNAXS's Avatar
Default Running extremely rich and already burnt plugs twice!
Some one help me. I have a Nitrous Works wet kit with the following
Tuning by Jayson(MTI) with 24 degrees of timing and Im running EXTREMELY rich
Vortex Fuel Pump
MSD WIndow S. 3 and 6
I just dont know what is going on. The first time this happened my car burnt a valve bc it hit the limiter, SOLUTION: MSD window switch, pulled back timing and Richened it up Max.
Now it has happened again. I disinegrated 2 spark plugs AGAIN.
150 Shot of Juice. Wich is equivelent to probably a 120 TNT.
Someone suggested something is wrong with the Fuel Solenoid?
Old 07-04-2003, 07:55 PM
383LQ4SS's Avatar
Default Re: Running extremely rich and already burnt plugs twice!
is it the same cylinders that are always burning up? What did your a/f say on the dyno? Could the fuel solenoid be operating intermitantly? You are obviously going lean and/or detonating in those cylinders.
I would run some race gas if you are going to continue to trouble shoot your system until it is resolved.
Old 07-04-2003, 09:41 PM
Restricted User
CAT3's Avatar
Ditto with 383, rich ***** up the plugs, which nitrous is really good at cleanign them.. Lean however fries 'em. What kind of plugs you running? using a 150shot, you need a colder plug, and then the right gap as well.
Old 07-05-2003, 12:20 AM
SNAXS's Avatar
NGK TR6's gapped at 40. Yes its the same cylinders that are burning up, not sure on my AF.
Anyway I have decided to go all motor so MTI tuned my car all motor. I would like to know what the problem was. Ill ask MTI what my AF ratio was though...
