NOS illuminated purge?
Old Jan 18, 2008 | 01:33 PM
PAGregSS's Avatar
Default NOS illuminated purge?
I can't seem to find any clear pictures of how the purge tubing attaches to the cylinder with the LEDs on the NOS illuminated purge. Can anyone tell me if it has a fitting? Also, does anyone know the dimensions of the cylinder itself?
Old Jan 19, 2008 | 02:46 AM
PAGregSS's Avatar
All I can say in response is "wow". Apparently you are not familiar with what I'm referring to, thus no reason to respond. For your own sake, I will clarify. The illuminated purge has a metal cylinder that contains 5 LEDs through which the nitrous purges. I am not referring to a purge solenoid, I am referring to the housing for the LEDs.
Old Jan 19, 2008 | 05:30 AM
Beer99C5's Avatar
I believe it has a allen head set screw. The instruction set should be available at the holley site, then drill down to the NOS site and the instructions.
Old Jan 19, 2008 | 07:41 AM
PAGregSS's Avatar
Thank you! That is exactly what I was looking for. From the pictures I found, it looked like the hard tube went into the middle of the cylinder, but it didn't appear as if there was anything holding it onto the tube.
Old Jan 19, 2008 | 02:35 PM
streetvet's Avatar
I thought iknew, MY bad.
Old Jan 19, 2008 | 03:45 PM
Beer99C5's Avatar
I bought two, one already went bad, I am going to try the NX one (it is black vice chrome) when it is released. Not sure what happened, it was working great (and the BLUE Plume looked bad *** on the Blue Vette), had the head Cam install done (by someone else) and when it came back from the H/C install all the purge did is blow fuses, checked the wiring looks fine, disconnected it to get the purge functionality back.
