Need Wideband Curves, for a better V and P gauge.
Right now if your wideband has a PROGRAMABLE anolog out your good to go on the V or P gauges. But some widebands on the market do not have this option. The outputs are locked, and/or do not match our curve settings. So we are adding more options to the guages to ease the end users setup time and making the gauges a more complete all around units.
Right now we know Holleys and Fasts air/fuel Curves.
We are asking for your help. What other widebands are the yall using, and do you know the curves. exp. AEM, Autometer etc.
10-1= ? volts
20-1= ? volts
This will aid in these products having flawless interfacing.
Thank you,.
10-1= ? volts
20-1= ? volts
Thank you,.
LC-1 works with the V-Gauge fine as it you can program either of the two outputs to match the V-Gauge requirements.
The only thing I don't like about the V Gauge is when the WB is warming up the AFR displays 90 (but I can live with it
). Beer that is correct. The 90 means out of range or a problem. Example. IF you loose signal to your gauge you will also see a 90. Just a simple warning so sinceyour wideband is warming up, the gauge thinks its an error and lets you know it.
Glad you like the unit.
