window switch + spray out of hole....setup.
Old Jan 23, 2008 | 10:08 PM
Nimitz87's Avatar
Default window switch + spray out of hole....setup.
looking at the HSW dry plate kit w/ the interface, WOT switch, bottle heater, FPSS, etc.
my question is this.
can you set up to spray out of the hole at the track, and then have a window switch for the street?...how would this be done?
looking to spray a 100 shot out of the hole at the track and see how that goes....then might up it to 125, 150, etc. traction pending obviously.
with no window switch how do I limit the spray at the top and for shifting gears? (m6) is there just an RPM cut off switch?
and could I run a window switch on the street?
bascially what i'm asking is this.
when spraying out of the hole all you have is a WOT switch correct? then when you left off to shift the nitrous is cut and then back on right?
what If I want to run a window switch on the street and just a WOT at the track?....
Chad
Old Jan 23, 2008 | 10:23 PM
GT Griller's Avatar
Set ur "on" RPM's to what ever it is that u launch at....say u launch at 3k rpm set ur window switch to come on then, then just gun it outa the hole, spray should activate as soon as ur foot hits the floor.
Old Jan 23, 2008 | 10:32 PM
Nimitz87's Avatar
so if I launch at 5,000 I set it to 5,000 and then cutoff at whatever then right?
I was seriously over analyzing it.
Chad
Old Jan 23, 2008 | 10:37 PM
GT Griller's Avatar
Unless u got a 12 bolt i dont think ur gonna launch that high and be able to keep the RPM's that high......so say ur launching at 5k once the tires bite ur rpm SHOULD fall some, but u wotn have it floored to keep it at 5k before the launch....So i say on at 3k then off about 200rpm before ur shift point....say u shift at 6500 then ur off rpms at 6300.
Old Jan 23, 2008 | 10:38 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
my on RPM is 3000....the minimum I suggest setting it.
Launch rpm on the bottle is 4000+
The kit activates as soon as my foot hits the floor....feels like a dump truck rear ends me of the line
Old Jan 23, 2008 | 10:45 PM
Nimitz87's Avatar
built 9 inch, twin disk, full susp.
Chad
Old Jan 23, 2008 | 10:46 PM
Nimitz87's Avatar
alright I understand now, still run a window setup from 3,000 -6500 or whatever and your holding 4,000 dump/slip clutch WOT and hold on....
Chad
Old Jan 23, 2008 | 10:54 PM
GT Griller's Avatar
Chad
touche!!...didnt see it in ur sig
Old Jan 23, 2008 | 11:04 PM
Nimitz87's Avatar
yeah havn't added it yet
9 inch is waiting on the new center section, still need to order the Midwest Chassis torque arm, and the tex. exo-skel.
looking for mid 11's on motor and 10's on the spray.
Chad
Old Jan 23, 2008 | 11:45 PM
waterbug1999's Avatar
Well, mine is an A4 but kind of the same principal.. I have a 4K stall and is set to shift at 6600... I have the WS set at 3700 and turn off at 6500. I know the 6500 is too close to the 6600 but thats fine with me, I cant even feel it turn off and it prolly sprays thru the shifts.
Old Jan 23, 2008 | 11:47 PM
Chad
I have very similar mods as you, only thing is I run the X3 cam and have a 90/90.. If you are a good driver, I dont see any reason why you cant hit your goal. Good Luck!
Old Jan 24, 2008 | 12:11 AM
Nimitz87's Avatar
thanks, your setup is badass for sure.
it'll be a while for the nitrous, need to learn how to drive it first w/ a twin disk, an d full susp...
Chad
Old Jan 24, 2008 | 12:15 AM
jmill96Z's Avatar
You're gonna be suprised how fast that car will be.
On my old 6 speed setup I would set the WS at 3K and launch at 5500 dump. I never touched the bottom end of the switch, but if you miss a shift you will be more than happy it's there.
Chad
LOL, the A4's are alot easier to drive.. I have more left in the car, I just need some track time to get a descent tune down. Then crank up the N20 to a 150 or 200 shot and see what happends. But, gotta get a roll cage as I all ready got kicked off the track. :-(
Old Jan 24, 2008 | 12:17 AM
GT Griller's Avatar
are u tuned for ur spray or just for the heads and cam?
Old Jan 24, 2008 | 12:28 AM
I am tuned for the spray.. I lost ~20hp on the dyno from N/A to the N20 tune... Its a safe tune at that as well.
Old Jan 24, 2008 | 12:34 AM
Nimitz87's Avatar
oh I know...thats why I need to get the mod and get use to some power and actually hooking it....im sure it'll be a huge difference w/ just the susp. ****.
+ I honestly only have a few passes under my belt...I need to take it slower.
Chad
Old Jan 24, 2008 | 12:52 AM
jmill96Z's Avatar
You might want to take a day or two at the track getting used to the car on motor runs before you spray. If this is your first time spraying, it's a completely different animal when you hit it off the line.
Old Jan 24, 2008 | 12:57 AM
You still have a stock shortblock?
Old Jan 24, 2008 | 02:12 AM
jmill96Z's Avatar
Stock cubed. Forged pistons and rods
