good nitrous cam for my application
Old Jan 25, 2008 | 12:11 AM
chetmo's Avatar
Default good nitrous cam for my application
ok guys, basically i have read read and read, at first i was set on a big nasty cam like a Trex or HPE megadeath, but the more i read ill need a huge stall and big gears. the mods on the car will be as follows:
headwork on 241 heads..minor head work to help with flow
performabuilt tranny with a 3200-3600ish stall
(currently have 3.73's, might be willing to go 4.10's when i put in the 9 inch)
HSW nitrous wet kit.. car will be seeing a 100 shot
and the other bolt ons, LS6 intake, headers, cai, etc.
my goals for the cam....go big or go home, works well with the nitrous, suitable for my stall/gears applications, LOPEY, street manners mean very little, car wont be daily driven. basically i dont want a cam to have NO low end torque on all motor, i would like something to perform well on all motor, have low end TQ also.
Old Jan 25, 2008 | 12:53 PM
chetmo's Avatar
anyone?
Old Jan 25, 2008 | 01:16 PM
2002t/a06's Avatar
well imho i wouldnt go with a huge cam for the spray...bigger is not always better but you know that already. dont waste your money on an hpe cam....please dont...
Old Jan 25, 2008 | 02:05 PM
c0ncEpT's Avatar
People have had pretty good results spraying on an MS3 (237/242 .603/.609)
Trmin8r Made something like 620-640 spraying a 200shot on his Cam only MS3 car.
Old Jan 25, 2008 | 02:07 PM
2002t/a06's Avatar
he will need bigger than a 3600 stall to take full advantage of that cam.
Old Jan 25, 2008 | 02:25 PM
c0ncEpT's Avatar
Well I think the spray is going to help flash that converter just a little bit higher.
Old Jan 25, 2008 | 02:27 PM
2002t/a06's Avatar
that is true. not sure how much higher though.
Old Jan 25, 2008 | 02:57 PM
Stang's Bane's Avatar
Unless you are spraying over a 200 shot on regular basis, just buy a cam for your NA needs.
And yes the cam will flash the converter higher..
Old Jan 25, 2008 | 03:16 PM
c0ncEpT's Avatar
I agree
Even something like a Torquer 3 (231/234 .643/.598) would make great NA power, work well with the 3600 converter you have and take to N2o well.
Old Jan 25, 2008 | 03:41 PM
2000 Ultra Z's Avatar
My car ms3,3800 stall, 3.42, full bolt ons and 150 shot 10.89 @ 124 1.75 60' not spraying out of the hole 10 bolt. The 4.10 gears will help you out n/a my best n/a was 12.0 @115 this was all on a mail order tune for texas speed
http://videos.streetfire.net/video/6...5a011ab51d.htm
Old Jan 25, 2008 | 04:00 PM
RoWDyWS6's Avatar
3800/4000 stall or bigger?
Old Jan 25, 2008 | 04:21 PM
GT Griller's Avatar
Torquer 2 or MS3...both work really good with nitrous....got a buddy running the torquer 2 tuned for spray..picked up 106hp on just a 75 shot.....runs mid to low 11's on the 75 shot and thats with a 5500 DA...stock heads and a Vig 3600 stall.
Old Jan 25, 2008 | 04:23 PM
GT Griller's Avatar
If it was for an NA car id say 3800 would be just fine for a MS3.
Old Jan 25, 2008 | 04:38 PM
WizeAss's Avatar
buy a NA cam and spray it..... nitrous just increases cylinder pressure by the boatload. If you want to do something more specific.... increase the LSA over 114+ and go longer on the exhaust duration. Nitrous performes the best from 3000-5500.... so make your power there and keep the motor alive. And stick with a 4000 stall... unless you plan to spray over a 200 shot... then I would get something tighter or more expensive.
Old Jan 25, 2008 | 05:09 PM
ya but the 4.10 gears will help with a smaller stall
Old Jan 25, 2008 | 06:02 PM
JPH's Avatar
JPH
You do not need a "NOS" profile cam, you can use a standard dual pattern design and make great all around power/trq., and still perform excellent on spray. Custom Crane HR5 Lobe 232/236 .600/.600 112+3.5 will do EXACTLY what you want it to do.
Joe
Old Jan 25, 2008 | 10:40 PM
chetmo's Avatar
i REALLY appreciate the input guys, i really really dont want to go over a 3600 stall, im looking towards the MS3 or a custom grind of some sort.
Old Jan 26, 2008 | 12:23 AM
eric01ss's Avatar
get a torquer 2 man it will work good!!
my cam is a 232/232 on 114 and i cant wait to spray it with a 100 shot
Old Jan 26, 2008 | 08:37 AM
streetassasin's Avatar
Ive heard the GMPP ASA cam responds well to the spray, any one with experience?
