I need help
Old Jul 9, 2003 | 10:43 AM
turbodreamsLS1's Avatar
Default I need help
A friend of mine wants to sell me a NOS kit that he had on his last car which was a honda CRV , talk bout sleeper. But anyways will this work if I hook it up before the MAF? I was thinking spraying through that it would compensate the fuel for the nitrous. Please give me feedback it will be greatly appreciated
Old Jul 9, 2003 | 01:12 PM
n2o's Avatar
n2o
Default Re: I need help
I do not know if you can get a good mixture doing it but yes it will work if you put the nozzle in the side of the airbox. It needs to be 6inches from the maf to work properly, thats a fact. Maybe someone else can tell you about a single dry setup. Or you could fix it to where you have 2 lines coming to the airbox like a 5117. Hope this helps.
Old Jul 9, 2003 | 01:15 PM
well i just got the kit and there is a line that goes to the fuel pressure regulator to boost the fuel. So im guessing that i dont need to spray through the MAF. So i will keep ya'll posted on how it comes out
Old Jul 9, 2003 | 01:42 PM
slow's Avatar
your going to run a line all the way to the fuel tank...
On a LS1 dry kit all you need is:
bottle---feedline----selonoid----feedline---jet---nozzle.
the Fuel Pressure lines, ect, are for cars with vacuum referenced fuel pressure regulators, the ls1 is a semi-returnless style system.
Ryan.
Old Jul 13, 2003 | 10:18 PM
So should the stock fuel system provide an adequate amount of fuel to spray a 60 shot or will i need to make some changes???..... i hope to get a 100 shot soon
