witch is a safer Nitrous system
Old Jan 30, 2008 | 08:54 PM
302_5.0's Avatar
Default witch is a safer Nitrous system
im shoppin around for them and i cant decide i want a wet kit http://www.nitrousoutlet.com/catalog...roduct_id=1562
or..the ones that inject through the throttle body and goes through the upper and lower intake -thanks guys-
Old Jan 30, 2008 | 09:25 PM
Tom's_03SVT's Avatar
Dave will take care of you, PM him
Old Jan 30, 2008 | 09:27 PM
Nitro Dave's Nitrous Outlet's Avatar
If you plan on spraying no more than 150 to 175 a single nozzle before the throttle body will be fine. If you plan on going higher I would suggest the plate that goes between the upper and the lower intake. The ford 5.0 intakes start seeing flow limitations above the 175 mark.
Dave
Old Jan 30, 2008 | 10:29 PM
myfast70's Avatar
You should take a look into HSW kit. They have an awesome plate with the best spray pattern out there! They've also got smoking deals on their kits right.
Old Jan 30, 2008 | 10:48 PM
white2001s10's Avatar
IMO none of the wet kits are safe when you run them through an intake manifold designed for dry flow only.
If you care about safe, go with a dry system,
unless you want to spring for an individual port fogger system.
