Shift lower for nitrous?
Old Feb 3, 2008 | 07:36 PM
98LSGun's Avatar
Originally Posted by LS2Camaro
There is pretty much no use for me hitting the Nitrous in first gear, I spin bad enough as it is, the torque is too much for hitting it in first. From second on though that is a different story, I agree with what you are saying, and on a different note I need to get rid of these runcraps
i loving those sigs. nice cars dude.
Old Feb 4, 2008 | 01:31 AM
SmaknaSS's Avatar
Originally Posted by n2ocamaro
Shouldn't the shift point be determined bt the power curve? I would think you could look at a dyno pull and find where the power starts to fall off and go back a couple of hundred rpm and start there. Just a thought!
I'm on a stock Short block and that's what I do.
Old Feb 4, 2008 | 08:20 AM
bluehawk2's Avatar
The only reason that I set the shift points sooner is that the nitrous makes me blow through the shifts a little sooner.
