what jets do i use for this set up???
Old Feb 1, 2008 | 07:49 PM
FANCHERFAST's Avatar
Default what jets do i use for this set up???
i am using a Harris Speed Works nitrous soleniod with a .078 orfice and a Harris Speed Works fuel soleniod with a .125 orfice. these are running through a Zex peremiter plate. does anybody out there know what jet sizes would get me close to a 100 HP shot?? thanks for the info.
Old Feb 2, 2008 | 06:47 PM
bump for the day. i really need to know so i can buy some jets.
Old Feb 2, 2008 | 06:54 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
you will use the jetting for the ZEX plate and the fuel pressure you are running
Look on ZEX's website they have the manuals for most of their kits online, or call COMP customer service directly. They will be able to get you the correct jetting for your application
Old Feb 4, 2008 | 06:46 PM
i have talked to Chris at the Nitrous Outlet and he told me the same thing. i have contact Comp and i am waiting for a returned answer. i even asked HSW and they know nothing about ZEX. i just need to know where to start, and apperently no one has done this combination yet.
Old Feb 4, 2008 | 08:16 PM
jmill96Z's Avatar
The noids really don't make a difference for the kit. The plate is the only part that matters and, other than fuel pressure, is what the jetting is based off of.
The only issue would be if the noids you have are smaller than the Zex kit, but the smaller noids are pretty standard across the board.
