99.9% safe nitrous setup?
I saw the pictures of a members c6 in their driveway and half of the car is burned. I'm assuming that the member used a dry shot, but I may be wrong.
So I am asking this: What causes people to have bad experiences (like above) when using nitrous? Can a wet shot or direct port prevent this problem? Is it much safer to play with a direct port than a dry? Or is nitrous in general prone to accidents no matter the type setup?
And thanks for the nitrous outlet link!
We do a lot of direct port installs and would be more then happy to work you up a good price. We do a lot of very trick setups that look sexy and are top of the line in terms of function
I appreciate the post from you as well Mike.
It seems as though no matter the route, the only thing to keep it safe is to fully take advantage of the accessories or additional options one can get with a nitrous setup like those mentioned in all the posts here.
Thanks for all the great info.
To the original poster, you have it wrong. Try to find anywhere in the nitrous world a DRY hit car that has burned, you will not. You should read the wet vs dry thread, a very long read but really insightfully. You get truck loads of info on both types of systems. these days i always ask, give me one good reason to go old tech wet over new tech dry on the EFI/LSx platform. Many new dry products on the market these days that make it a no brainier, wet hits are certainly starting to diminish as the favorite style. Anyway, good luck on your choice and n2o can be a safe power adder.
Wet vs Dry Thread
Robert
I ended up with basically every safety switch you could buy, a stand-alone, plate first stage, direct port second....
I looked into the dry kits and without me personally tuning my car I decided against it. Plus to run teh size shot I wanted to run I would of had to switch to low impedance injectors...It just wasn't worth the trouble to me.
Although it seems like you're really not going to be spraying enough to warrant 2 stages or a large kit. I would suggest a dry system plumbed into a plate with either efilive cos 5 or the hsw controller for anything below a 200 shot. At around 200 you need to look at a directport simply for saftely. Wet nozzles can easily spray 300 shots but just not safely.
Also before you make the leap to direct port you need to look at the head set-up you may want to run for the larger cubes. If you plumb a direct port to a fast 90 and then later switch to ls7 heads for the larger motor you would have to redo the direct port on the new intake.
I would have to give a shout out to nitrous-outlet for their systems and tech service...
Hey Lythropus, good input. To clarify a couple things, on the dry shot and injectors, we now have 80lb'ers we can run with out going to after market PCM, Racetronics has them. Also, on the going to DP on over 200hp shots, true for Wet, but the dry hits do not run into drop out problems like the heavy gasoline. So, going straight down the neck before the MAF, and limits has not been found for any reason that I am aware of, and have gone as far as 300, and over that then yea maybe DP should be the limit? I chose to go DP Dry this time around as the Interface and/or the EFI Live COS 5 (though I don't know anyone yet using the EFI live for a DP Dry) makes this a no brainer, IMO, and the temps per cylinder are closer with a dry DP than a Wet DP and that shows the Dry DP as the better distributor.
Robert
heres a good found:
https://ls1tech.com/forums/showthrea...t=dry+backfire
contains this post by Dave at nitrous outlet;
Like I have stated many many times.. Coming from a NEUTRAL standpoint. I have delt with alot of cars and a lot of nitrous setups. I have seen backfires from both DRY and WET nitrous systems. I have seen blown motors from both DRY and WET nitrous systems.
Granted I have been around helping and working on alot more cars than some.
A backfire through the intake is normally a lean pop.. However there are other ways to cause it..
The only thing that can truthfully and accurately be said is that a nitrous backfire with a wet system is normally more violant than one with a dry system.(The reason why is with a wet system there are more Fuel vapors in the intake than with a dry system.
Most all backfires are caused from the following,
Bad tune up- To rich/ to lean, wrong timing
Spraying under to low of a RPM
Taging rev limiter.
FOR EVERYONE READING..
All nitrous systems require knowing your tune up.
Dave
_______________________
with this said, a lean wet AND dry shot are ugly. Get a WIDEBAND to know your a/f ratio before spraying at will. I've been reading for 2 months now in this section and I'm really happy I did before spraying!!
What your grandpa told you was true. If you can't afford to risk something, then don't.
Your best risk is with a simple dry shot.
If spending more money makes you feel safer, then go with a dry direct port system.
