few questions about dedicated fuel system
Old Feb 8, 2008 | 04:48 PM
BCNUL8R's Avatar
Default few questions about dedicated fuel system
I'm going to be installing a dedicated fuel system on my GTO soon and just want to gather some more info before I jump in.
Are you guys running a fuel pressure gauge on the dedicated to verify fuel pressure or are you just putting the high pressure spring in the regulator and calling it good? I would like to closely match my current fuel pressure at about 58 psi. so I can stick with familiar territory as far as fuel jetting.
Does the fuel line from the dedicated go directly to the fuel solenoid from the regulator which would also have a return line correct?
Where are you getting power for the fuel pump?
Sorry for all the newbie questions, but better to look like an idiot now than after I figure out I did something wrong and break something at the track.
Old Feb 8, 2008 | 08:11 PM
Robert56's Avatar
In my web some info on wiring your pump, and maybe some other insight that may help.
Robert
