Who is running a Mechanical N20 gaue in a pillar?
I have one and the damn Autometer 6' line is more then the gauge. Looking at the 3228. What are my other options? Would a standard 4an line work just the same? I do not have the gauge in my possesion but I assume the back of the gauge is a standard 4an???
the line has to handle the 900+ psi that you use in a N2O system. So you need one for nitrous. do you need the 6' line? Have you checked Nitrous Outlet? Here are some lines http://www.nitrousoutlet.com/catalog...del=81&dept=11
Good luck.
Good luck.
