hsw dry kit install
well im installing my hsw sudden impact dry kit. well ive been looking at some of the pics. on the image gallery on there website, and im still cant seem to figure out how to install the wot switch. i would also like to know where you guys mounted youre solenoid. also in the instruction they send they say to mount the nozzle within one to three inches of the maf, well i was planning on keeping it kind of hidden and stick the nozzle through the bottom of the airbox. you guys think that will affect my experience with nirous in any way?
thanks in advance.
The whole point is to get a solid stream of spray flowing across the MAF. The further you get away from it, the less effective it will be.
or, as Jmill stated, you can mount the switch on your gas pedal so it can not be seen under the hood.
as far as Knozzle placement...if your lookin to try and hide the system you may want to think about the Interface which will allow you to put that knozzle anywhere you want and not worry about running lean or playin with jet sizes.
you can put the knozzle in the lid but it may need to be turned toward or away from the MAF depending on how rich or lean its running.
hope this helps, if ya have anymore questions, feel free to ask. enjoy the kit!!
Rick
