what jets for low fuel psi?
Old Feb 9, 2008 | 08:39 PM
021less's Avatar
Default what jets for low fuel psi?
I'm gonna be running a 150 shot and a stand alone fuel system so i can run race fuel with the n2o. My question is, my setup is a low pressure system and i believe the max psi is 14 that the pump can put out. Can anyone suggest what size jets to use on the fuel side for the low pressure? Just got my timing twister the other day so i'm about to start the install. I have jets from 50-200. Or should i just take it to my tuner and let them figure out what size to use? Thanks.
Old Feb 9, 2008 | 08:44 PM
madclown's Avatar
I would use a tuner on the dyno........
