PLUG GAP TR6 WITH 125 SHOT
Old Jul 12, 2003 | 04:55 PM
WS6snake-eater's Avatar
Default PLUG GAP TR6 WITH 125 SHOT
Hey guys I'm putting in my cam right now, and we are changing plugs to the tr6's since we are right there. What gap should I use..I am going to be running a 125 wet shot? Need quick answer thanks.
Old Jul 13, 2003 | 03:48 AM
Fast SS on TNT's Avatar
Default Re: PLUG GAP TR6 WITH 125 SHOT
I would go with a .35 gap. Thats what I run, and never have a problem with mine.
Old Jul 13, 2003 | 07:44 AM
CAT3's Avatar
Restricted User
I gapped at .038 and got best NA and N2O runs. Every car is different, so gap em around there and make a few runs, next time try a .001 up or down and make both NA and N2O runs to set it.
Old Jul 13, 2003 | 08:33 AM
scalemaster's Avatar
I got the NGK-TR5 and there gap at 35
Old Jul 14, 2003 | 06:54 AM
Oh ****, I gapped them at 60. What's going to happen? Do I need to get back in there and pull them all again? That was a serious pain in the ***.
Old Jul 14, 2003 | 09:14 AM
Assassin's Avatar
should only take about 1/2 hour, you should for sure regap them!
Old Jul 14, 2003 | 09:30 AM
damn ok. I've still got to put on the y-pipe so I will go ahead and regap them on my lunch break. I have the car on the lift right now. So I guess the consensus is to go with a 35 gap, is that correct?
Old Jul 14, 2003 | 09:35 AM
Somebody shcool me on plug gap, how does opening and closing the gap affect the vehicle. what is the rule for gapping with nitrous do you want a bigger gap or a closer gap when running nitrous?
Old Jul 14, 2003 | 11:17 AM
Tim 98z's Avatar
Bigger gap means hotter spark. Hotter spark means posible lean condition. Also bigger gap, the nitrous will more than likley blow the spark out. Smaller gap colder spark safer...
Old Jul 14, 2003 | 11:52 AM
excellent explanation thank you
Old Jul 14, 2003 | 12:01 PM
CAT3's Avatar
Restricted User
What Tim said, and you want it wide as possible without blow-out and leaning. Like I said, I ran .035 to start, no problem, opened the gap up to .038 and picked up new best, both on and off the bottle. I even gapped at the track the same night to make, and more than once.
