IAT how to with PIC...
Old Apr 1, 2008 | 12:06 AM
Goldfinger911's Avatar
If you're not going to change your tune, a '98 LS1 should be able to pull 3 degrees from 95kPa, starting at 50c IAT, and from 90kPa from 55c IAT up. If you are going to change your tune {B5911} or get fancy with a dual relay setup, for different timing pulls, here is the sensor data on what resistor you will need to mimic the stock IAT sensor. The table only goes up to 90*C on a '98 so thats all I pasted. I am running two relays for my two stage progressive system. One stage pulls 3 degrees and one pulls 6 degrees using the 80c and 90c rows of the IAT Spark table (modified).
9420 ohms = 32 *F - 0 *C
7280 ohms = 41 *F - 5 *C
5670 ohms = 50 *F - 10 *C
4450 ohms = 59 *F - 15 *C
3520 ohms = 68 *F - 20 *C
2796 ohms = 77 *F - 25 *C
2238 ohms = 86 *F - 30 *C
1802 ohms = 95 *F - 35 *C
1459 ohms = 104 *F - 40 *C
1188 ohms = 113 *F - 45 *C
973 ohms = 122 *F - 50 *C
<---750 ohms would give you the default 3 deg here at 55c.
667 ohms = 140 *F - 60 *C
467 ohms = 158 *F - 70 *C
332 ohms = 176 *F - 80 *C
241 ohms = 194 *F - 90 *C
Click here to SEARCH for Resistors
Old Apr 1, 2008 | 01:22 AM
backrdrunner's Avatar
Originally Posted by Frost
If you have HPT or EFIL, select a resistor value greater than 105K and it will force the IAT to the bottom of the table, -40degF, which is currently 0. IF you have an 01-02, pull timing from .60g/cyl and higher. If you have a 98-00 use the 95 and 105kpa cells in the -40degF column. If you have an 01-02 (or 01-02 OS on your 99-00) you get a PE modifier against IAT also, which will let you add or subtract fueling from WOT, which is sweet
Frekin brilliant information..thanks
Old Apr 1, 2008 | 08:15 AM
Jpr5690's Avatar
Wow Had I Known That O Wouldent Have Bought My Hsw Interface
Old Apr 1, 2008 | 07:14 PM
Robert56's Avatar
Would it be alright to steal the info and add it to my site? Though I will give you credit for the info? You wouldn't believe how much I get asked for this info, lol. For me, adding more relays to my already 7 relays isn't what i want to do, so I will stick with the Interface and have as many tunes I as need/want with out changing resistors. however, that why we have come up with using the pot, then just dial in what ever resistor you like. you do have a trick way of doing your dual stage though.
Robert
Old Apr 2, 2008 | 09:56 AM
Sure man! No prob. I am always willing to share. (especially with my PacNW peeps)
Yes the dual stage is nice and simple. You just have to make sure that the relay "closest" to the ECU side of the harness is the one that enables the higher temp (lower resistance value). I run an NX Maximizer progresive for my main stage and it has an output for timing retard. I run it to the switch side of one of the relays. That same output now also turns on my Boost-a-Pump. The second relay pulls less timing, because my second stage is a smaller shot.
Robert
Old Apr 2, 2008 | 07:10 PM
Robert56's Avatar
Cool. My multi stage set-up does about the same, though I go about it differently. Come on out to one of our races and we can talk dual stage, lol.
Maybe, run our cars and make a dual stage champ, hehehe.
Robert
Old Apr 3, 2008 | 09:02 AM
Jpr5690's Avatar
What About If You Used The Ect As A Way To Pull Timeing .. Wouldent This Alos Work? What Other Variables Would Be Affected (yea I Laready Know The Fans Would Turn On)
Old Jun 30, 2012 | 10:34 PM
kllrvet's Avatar
Good stuff for tommy
