converting dry to DP
Old Feb 13, 2008 | 08:38 AM
landonew's Avatar
Default converting dry to DP
How Expensive is it to convert a dry system (MAF) system into a DP system. The reason i ask is that i eventually want to go w/ a DP setup, but not until i have a forged shortblock. How much money would i be wasting if i went with a dry system now and converted to a DP kit later. It seems that the lines would be run, and the bottle/saftey features (window switch, WOT switch, bottle heater, ext.) would be transferable. Seems like i could sell the nitrous plate when the time came and i wouldn't be too bad off. Any opinions???
Old Feb 13, 2008 | 09:06 AM
Rick@HSW's Avatar
just need to get the knozzles and lines...removing and plumbing the intake. if your going wet, fuel solenoids and possibly another nitrous noid if you wanna run a split set up (1 Nos, 1 fuel per side). and make sure the fuel system is up to the task...ie: injectors, pumps etc. a stand alone set up would probably be a good idea aswell. all in all cost wise you could be lookin at a few hundred bucks depending on what you decide to do. hope this helps..goodluck
Rick
