Need Pics of WOT placement on LT1
Old Feb 17, 2008 | 11:50 PM
justatoy's Avatar
Default Need Pics of WOT placement on LT1
Could some of you show your pictures of the WOT setup you have on the LT1 motor. Mine seems to be too close to the intake elbow. Just looking for some ideas and examples for my setup. Thanks
Old Feb 18, 2008 | 07:36 AM
LS1 SPEED's Avatar
I would suggest the Nitrous Outlet TB bracket. They do not have a pic for some reason, but I just put one on my car it worked out great.
Old Feb 18, 2008 | 02:24 PM
Jditlfm's Avatar
It was very tricky deciding on the proper place. Mine works perfect. I prefer it on the pedal.
Old Feb 18, 2008 | 02:47 PM
quickblade's Avatar
I would say set it up so you can hit it.. makes you feel like need for speed.
LOL
Old Feb 18, 2008 | 05:40 PM
justatoy's Avatar
I like the pedal idea. Just seems with a little vibration the switch could get stuck down with all the other items around the throttle body. Any more pics?
Old Feb 18, 2008 | 07:35 PM
itSSlowZ28's Avatar
i'll be putting mine on tonight from HSW. hopefully have pics up late tonight
Old Feb 18, 2008 | 07:52 PM
jmill96Z's Avatar
On my LT1 I had it on top of the throttle body using the front 2 driver side bolts. It is definately not incognito, but it worked, and it was easy to make adjustments.
The car is long gone, or else I would post some pics for ya.
Old Feb 20, 2008 | 01:49 AM
itSSlowZ28's Avatar
i completely forgot to take pictures. i'll get some tomorrow night for sure while i'm working on the wiring
Old Feb 20, 2008 | 07:09 AM
XX11SECZXX's Avatar
i like the pedal idea anyone else using it with problems?
Old Feb 20, 2008 | 07:56 PM
foggedz's Avatar
Mine is mounted right off the pedal also. Never had any problems.
Old Feb 21, 2008 | 10:45 AM
itSSlowZ28's Avatar
as promised, my WOT switch and bracket from HSW
Old Feb 21, 2008 | 06:55 PM
justatoy's Avatar
Thanks for the pictures. I still like the gas pedal spot. Just don't want it too obvious.
Old Feb 21, 2008 | 08:01 PM
LT1PwrdZ's Avatar
Mine is tied into the TPS and uses the Curve to WOT engage the nitrous, But the pedal looks good. just mount it good and tight
