zex kit
Old Feb 18, 2008 | 11:41 PM
Jrp1978's Avatar
Default zex kit
I just bought the zex kit what else do i need to make is safe ?
Old Feb 18, 2008 | 11:42 PM
Jrp1978's Avatar
Default ohh
I am a six speed car
Old Feb 19, 2008 | 01:08 AM
Caribe's Avatar
Window Switch, Fuel pressure safety switch, NGK Tr6 spark plugs.
Old Feb 19, 2008 | 01:18 AM
Jrp1978's Avatar
Default ok
do you have a part # for the switch and is there anything else i would need to hook it up ( fitting I mean) and i what about a purge kit is that a must or not? Window switch ? witch one do you recommend?
Old Feb 19, 2008 | 05:23 AM
Caribe's Avatar
Dynotune has a lot of the stuff you will need. I would also recommend a nitrous filter and pressure gauge
http://www.dynotunenitrous.com
Old Feb 19, 2008 | 09:06 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
I would go with a window switch:
http://www.dynotunenitrous.com/store...?idproduct=194
and a lean safety shut down switch
http://www.dynotunenitrous.com/store...p?idproduct=67
NGK plugs is also a good recommendation.
Enjoy!
Dean
Old Feb 19, 2008 | 09:10 AM
Mike@HSW's Avatar
I would read through this sticky
https://ls1tech.com/forums/nitrous-oxide/846230-everything-nitrous-related-stock-bottom-end-all.html
There is a lot of great information in there about saftey accessories. Depending on what size shot you will be running, some are or arent necessary. If you still have any questions please let me know i can help you out.
Mike
Old Feb 19, 2008 | 11:20 AM
fasttimes1's Avatar
As for the Zex kit, doesnt the "active fuel control" monitor the pressure for you? Would you need a fpss?
 Michael S. Palmer
Old Feb 28, 2008 | 12:50 AM
ZiOhSix's Avatar
no you wont need a FPSS with the zex.
