Safe to spray a stock LT1?
Guest
Posts: n/a
I would go with a wet kit as most dry kits for the LT1 increase fuel pressure for the fuel enrichment, and the OEM injectors were not designed for 80+psi.
But with that being said yes you can run dry on your car, just make sure the injectors/fuel pump are in good condition. You read the nitrous accessories outlin ine the FAQ sticky, and decide which features are right for you.
If you have any questions feel free to give us a call.
