Nitrous regulator question
Old Feb 26, 2008 | 07:31 PM
myfast70's Avatar
Default Nitrous regulator question
I've been contemplating the purchase of a Nano system and came across this Zex nitrous pressure regulator. I was wondering if you could get the same results (no pressure drop during a run) by turning up the bottle to pressure to say 1300 psi and set the regulator to 950 psi output. Would you be able to maintain the 950psi during a full pass? You would have to play with the starting pressure a bit but once figured out it should stay consistent. Is my thinking way off here? If this would work you could potentially get the same results of a Nano for less than half the price. The regulator is rated for a 500 shot so there shouldn't be any restrictions of flow.
Old Feb 27, 2008 | 08:27 PM
myfast70's Avatar
Anyone?
Old Feb 27, 2008 | 08:42 PM
383LQ4SS's Avatar
Ok...I liked this product ALOT when it came out. But IMO it hasnt been tested (by us here at LS1tech) so I dont have any good feedback.
If it works as advertised...you could rejet your setup so it will run with alot less bottle pressure. Tehn use a heater to keep bottle pressure much higher than your "set pressure" on this regulator and if it works as advertised it would maintain a nice flow.
Will it be as good as NANO? I am not sure. Several tests would have to be performed.
Someone needs to buy this and test it. It it does what they claim...should be a viable product.
Old Feb 27, 2008 | 10:40 PM
myfast70's Avatar
I think I may buy one by this weekend. I don't ever plan on spraying anything over a 200 shot on one of my cars so I probably won't be able to give it as good a test as you or Robert but it should be interesting. Do you know if there is sensor that I can hook up to my LM1 wideband so I can log the pressure during a run?
Old Feb 28, 2008 | 09:51 AM
cyipher's Avatar
kinda looks like a palmers paint ball regulator
Old Feb 28, 2008 | 10:36 PM
myfast70's Avatar
It sure does! I just checked their website and they're almost a direct match. I'll have to call them tomorrow as they custom build regulator for "non paintabll" applications and they can go up to 3000 psi. Thanks for the insight I was just ready to buy the Zex piece.
Old Feb 29, 2008 | 12:25 AM
cyipher's Avatar
let us know what you find...
Old Feb 29, 2008 | 07:05 AM
myfast70's Avatar
No problem! If they work you can get two for the price of the Zex I posted above.
Old Feb 29, 2008 | 07:34 AM
PAGregSS's Avatar
I would think the mentioned product would help maintain nitrous pressure, when the bottle has good pressure. I would doubt it would work as well as the Nano though, because the push system is actually forcing the nitrous out of the bottle.
