nitrous outlet progressive controller
Old Feb 27, 2008 | 09:52 PM
tsneath's Avatar
Default nitrous outlet progressive controller
Is anyone running the nitrous outlet brand progressive controller. I got one last week and got it all hooked up but it does not seem to be working right. It feels like it is the complete shot at once. Here is a little bit about my setup. I have a nx electronic tps then a nx rpm window switch, fpss, and then my progress controller. I did not have any of my wiring info form before but I tapped into the fpss wire going to the relay for the solenoids for my ground trigger wire. As soon as I arm the kit the blue light comes on for about 15sec then shuts off. Is the normal?
Old Feb 28, 2008 | 05:37 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
How much is it going for? I need one for when I buy the unit soon.
Old Feb 28, 2008 | 08:27 AM
tsneath's Avatar
they go for arond $160 but this one is not for sell trying to make it all work right.
Old Feb 28, 2008 | 10:18 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Thanks for the call, this should get the issue fixed for you.
Old Feb 28, 2008 | 10:22 AM
AlexLs1's Avatar
I have one, its really easy to use. My only issue was that it needed to have a better tach source, so I went off of a coil pack. I love it, on the dyno with a 150 shot my tuner said it felt like a turbo car, it looked like it too minus the noise lol.
Its a great tool to have if your limited on tires, I was more nervous having my car with a heads and cam and a 150 with 275 nitto's Dr's, mine comes in about 30% at 3200 then at 4000 unleashes all hell. I'am still playing with it, for imbetween shifts.
Old Feb 28, 2008 | 10:46 AM
tsneath's Avatar
thank you very much I will get it hooked up right later on today and go play.
