(pics)GMPP W/ elbow N2O setup.
Old Feb 28, 2008 | 04:11 PM
IH8FORD's Avatar
Default (pics)GMPP W/ elbow N2O setup.
This is The nitrous set-up I am running It is a little different but I needed the hood clearance . Let me know what you think.
Old Feb 28, 2008 | 05:36 PM
Z28FirefighterI1's Avatar
That looks bad ***!
Old Feb 28, 2008 | 05:48 PM
JonCR96Z's Avatar
Old Feb 28, 2008 | 08:52 PM
RIDINFILTHY's Avatar
sweeeeeeeeeeeeeeeeet!!!
Old Feb 28, 2008 | 09:32 PM
JL ws-6's Avatar
Race your car!
Not bad, not bad at all. If ya really want to clean that up some more, try to run the lines thru and under the intake, maybe even Y them under the intake so ya have a single line to the noids.
I like hardline setups though, and that's a damn good job, especially if that was your first attempt.
Old Feb 28, 2008 | 09:35 PM
IH8FORD's Avatar
Thanks, It was my first time I am not totally satisfied with the lines. I am going to take the T off of the solenoids and move it under the TB. And run one hard ine from each solenoid.
Old Feb 28, 2008 | 09:45 PM
JL ws-6's Avatar
Race your car!
yeah, probably look cleaner that way. I'm thinking about hard lining the Nos plate kit I have, mainly to clean up the install just a little. What side line did you use, and what size are the tube nuts? I know all the connections I want to hardline are all -4an, so I know what I need for tube nuts and sleeves, not sure what size line I need though.
Old Feb 28, 2008 | 10:38 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You should put the solenoids under the cowl and run the lines forward. That would definetly clean it up.
Old Feb 28, 2008 | 10:45 PM
myfast70's Avatar
Damn, I want a black waterpump!
Old Feb 29, 2008 | 09:59 AM
IH8FORD's Avatar
My tube nuts are -3 so is the connections I have. I used 3/16 line. If you have -4tube nuts then you will need 1/4 line.
Old Feb 29, 2008 | 10:13 AM
insanez's Avatar
clean the rest of your engine bay and it would look bad a**. Just my $.02.
Old Feb 29, 2008 | 10:21 AM
JL ws-6's Avatar
Race your car!
1/4 inch line for the -4, thanks!
Old Feb 29, 2008 | 10:22 AM
W8N2SQZ's Avatar
I would be very careful running this set up. Distribution to all 8 cylinders is not very good with two nozzles positioned like that.
I had a buddy that tried 4 nozzles in a similar situation. Both times her ran it, it blew the motor. This was on a carbed setup but with a victor intake.
I would start out on a small shot and watch AFR and how the plugs look.
Glenn
Old Feb 29, 2008 | 10:50 AM
JL ws-6's Avatar
Race your car!
speedtech diffuser plate under the elbow if it will fit would be the shizzit
Old Feb 29, 2008 | 12:59 PM
b00sted's Avatar
It would look much nicer and probably work better with an NX plate if the hood clarance allows for it.
Old Feb 29, 2008 | 02:13 PM
xBROKEx's Avatar
that exactly what i was thinking. He would have to mount the solonoids to the engine back there because if he mounted them to the cowl the engine movement would mess the hardlines up pretty quick
Old Feb 29, 2008 | 02:16 PM
IH8FORD's Avatar
A plate was my original Idea but I will have clearance issues. I may still do a plate and cut the **** out of the bottom of the hood. I have a 100 shot in it now I am going to try it on the dyno and check the plugs right afterwards.
Old Feb 29, 2008 | 02:19 PM
IH8FORD's Avatar
Originally Posted by JonCR96Z
Jons a HOMO
Old Feb 29, 2008 | 03:06 PM
RedTtop6spd's Avatar
I'd definitely think about moving it to under the TB to try and shorten the lines up some. Looks nice, but I think I'd prefer shorter lines. I might also be concerned about that many bends.
Old Feb 29, 2008 | 06:32 PM
VH5150's Avatar
Dynojet Fan
its def.different...
