Those with nano.........how does it work??
Old Mar 6, 2008 | 10:51 PM
streetvet's Avatar
Originally Posted by Ping King
ill have to get a picture set together. I will list on the following things you need:
1. Bottle valve with a push port that goes to the bottle and not into the nitrous stream
2. Check valve
3. Nitrous line
4. roughly 117 ci tank that fills with 4500 psi will be enough for a 10lb bottle
The tank needs to either have an adjustable regulator, or an output that will equal your bottle pressure.
yeah, a 10lb bottle you might need a few setups to go 5 or 6 rounds. depending on how BIG of a shot you are spraying.I think there is more to it but what do i know . I like to have the 15lb NANO bottles and 1 back up, just in case .
watch
http://s259.photobucket.com/albums/h...ssedonBowe.flv
Watch this Nano launch ^^^^
With a bigger shot , a Nano setup is a MUST. It works. the other Vette is a turbo. We were lucky, he was hurt.
Thx Corvettechallenge.info/ for VID
Old Mar 7, 2008 | 03:05 AM
transAm-98's Avatar
nice vid. I can't wait to get one of these setups this summer
Old Mar 7, 2008 | 08:25 AM
algws6's Avatar
streetvet, nice vid. what tranny and rear end are you running?
Old Mar 7, 2008 | 04:31 PM
streetvet's Avatar
3 speed ( powerglide & GearVendors overdrive unit ). 4 link rear with ET streets.
Why ?? because i blew everything up at least 4 times (4rears + 5 trannys= $$$$$) . I like to RACE all day , week after week & still drive it on the street( when i want ).
Corvettes don't hold up to the power i had . i do HATE to break . Last season , NO break
ps NANO RULES
Old Mar 7, 2008 | 04:54 PM
algws6's Avatar
Wow!!!!!!!!!!!!!!!!!!!!!1
Old Apr 6, 2008 | 09:14 PM
C_Rules's Avatar
2. Check valve
3. Nitrous line
ping king any luck with this setup and the pictures?
Old Apr 7, 2008 | 04:19 PM
bad6as's Avatar
so if you want your n20 psi to be 1000psi then the paintball tank would need to put out 1000psi right?
i use to play paintball alot and the tanks output pressure is only around 850. having an inline regulator set at 1000psi. would that cause problems
