Trick performance window switch and zex
Old Mar 1, 2008 | 06:02 PM
Jrp1978's Avatar
Default Trick performance window switch and zex
OK i have a trick performance window switch and a zex kit . I can get the zex box to program. I cant figure this out ? I got the switch programed but not the zex box . Dave told me to hook accessory wire from toggle switch to red wire window switch . 2. pink wire from window switch to pin 86 3. pin87 realy to white wire on zex box . 4 pin 85 to ground 5. pin 30 to tps . All the done the zex box wont learn the tps voltage for wot ?
Old Mar 1, 2008 | 09:12 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
jump pin 30 and pin 87 to program the TPS then remove the jumper wire for normal operation
Old Mar 2, 2008 | 02:03 PM
Jrp1978's Avatar
Default ok
OK did that ..... now is the pink wire coming out on hot when it hits a certain rpm and gear from the window switch . Meaning with everything programmed and ready the wheni hit 2nd gear at 3000 the pink wire is gonna send signal to the relay and then fire the system right?
