need help with zex dry kit!
Old Mar 5, 2008 | 07:36 PM
Dustys Svt's Avatar
Question need help with zex dry kit!
I need help with my zex dry kit.it says u are supposed to tie into the fuel regulator well how do you do that the line going to the regulator is hard line not a hose what should i do guys pm with some info please.
Old Mar 5, 2008 | 08:39 PM
DeltaT's Avatar
You need to replace that section of hard line with something flexible, like stainless braided line, so you can plumb in your Zex box. Without knowing your setup I can't give you any more.
Jim
Old Mar 5, 2008 | 11:08 PM
Dustys Svt's Avatar
It is the kit that has the intake vavle and fuel regulator on one side of the box.not for sure what else you need to know.but you say to take out the hard line and replace it with braided line.
Old Mar 6, 2008 | 09:22 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
What type of car are you installing this kit on?
Old Mar 6, 2008 | 08:35 PM
Dustys Svt's Avatar
Trying to put it on my 99 TA.
Old Mar 7, 2008 | 11:14 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the kit for the LS1 does not need to connect the line to the fuel pressure regulator as it is in the gas tank
you will install the nozzle in front of the MAF and the PCM will take care of the fuel enrichment, no need to increase fuel pressure
Old Mar 7, 2008 | 11:45 AM
Dustys Svt's Avatar
So what do i do about the fuel regulator hose and intake valve hose on the zex box.
Old Mar 7, 2008 | 01:28 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
All you need to do is plug the vaccuum line.
Old Mar 7, 2008 | 06:43 PM
Dustys Svt's Avatar
I dont have a vacum line all the lines i have are the intake,fuel regulator,and nitrous feed line. are you talking about using my intake line as my vacum line if so were do i hook that up to on the intake.man i am lost.
Old Mar 7, 2008 | 06:48 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the line that would go to the Fuel pressure regulator will need to be plugged...it is a vaccuum line.
The nitrous flow creates a vaccuum, when this is connected to the FPR it will increse fuel pressure.
Old Mar 7, 2008 | 07:52 PM
Dustys Svt's Avatar
Thanks for the help man but the line that goes to the fuel regulator is metal.and what do u mean to plug it.
Old Mar 7, 2008 | 07:57 PM
jerrad's Avatar
You can buy vacuum caps that fit over vacuum lines. Go to wal mart, autozone, pepboys, etc.
Old Mar 7, 2008 | 08:06 PM
Dustys Svt's Avatar
Hey jerrad i seen you are from oklahoma so am i.i get that i have to tie into a vacum line but how and what line off of the box are you guys talking about please forgive me for being stupid i have never hooked one up and i just dont want mess nothing up.
Old Mar 7, 2008 | 08:53 PM
jerrad's Avatar
The line on the box that is supposed to go to the FPR will be plugged. So if you have a line coming out of the ZEX box you will put a cap on that line. Someone correct me if I'm wrong please.
Old Mar 7, 2008 | 09:53 PM
Dustys Svt's Avatar
I am starting to get it so the fuel regulator line comming off of the box put a cap or plug it somehow.one more thing the intake hose on the box what does it tie into or do i cap it or plug it to.
Old Mar 7, 2008 | 09:55 PM
Dustys Svt's Avatar
Jerrad what part of oklahoma are you from.
Old Mar 11, 2008 | 12:08 AM
Dustys Svt's Avatar
T T T
Old Jun 2, 2008 | 10:39 PM
Big Black SS's Avatar
so the intake hose on the zex box what does it tie into or is it also plugged ?
Old Jun 3, 2008 | 09:25 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
cap off both vacuum ports that would connect the NMU to the fuel pressure regulator and intake
Old Sep 29, 2008 | 09:21 PM
04BlackGmc's Avatar
thanks!
