150 shot in front of throttle body ok?
Old Mar 6, 2008 | 08:45 PM
azboostin's Avatar
Default 150 shot in front of throttle body ok?
I have an Lt1 car.. wonering if it would be ok to put two foggers in front of the tb on the cai and run a 75 shot out of each? how far should the nozzles be placed away ect..
Old Mar 6, 2008 | 08:49 PM
transam69230's Avatar
What kind of shot is is it wet or dry? there wouldn't be anywere else to put the nozzels really unless you had a plate kit i would think.
Old Mar 6, 2008 | 08:55 PM
azboostin's Avatar
wet... would try to tap them somewher ein the intake tube
Old Mar 6, 2008 | 09:07 PM
O6DODGE's Avatar
It should be that is how tnt, nx and just about every other nitrous setup.
Old Mar 6, 2008 | 11:06 PM
BOLO's Avatar
Nitrous Outlet has a nice plate system for the LT1. Just something to consider for better optimization imo.
Old Mar 7, 2008 | 12:07 AM
itSSlowZ28's Avatar
nozzle placement is pretty tricky on an LT1. i've seen a few good set-ups, but a plate i think is still the best option. and remember, if your running a t or y off of a solenoid to 2 nozzles jetted for a 75 shot, it may be a little off. i think its in one of the stickies.also, you probably don't want to cover your MAF in fuel on a wet shot. i'd do it into the intake elbow. heres a pic of a member's set-up
Old Mar 7, 2008 | 06:50 AM
azboostin's Avatar
I dont have a maf so thats ok..... does it hurt the little air sensor though?
Old Mar 7, 2008 | 11:07 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would suggest a single nozzle over a dual nozzle...but yes it can be done.
Here is another pic of a dual nozzle kit
Old Mar 7, 2008 | 05:25 PM
azboostin's Avatar
Can a single support 150?
Old Mar 7, 2008 | 05:32 PM
daniel6718's Avatar
yep
and plates overspray the front cylinders
Old Mar 7, 2008 | 07:47 PM
chavez885's Avatar
Sorry to hijack but...Ray which do you think is safer, plate or single nozzle?
