length of nitrous lines
Old Mar 6, 2008 | 09:20 PM
neals98's Avatar
Default length of nitrous lines
I got a used NX nitrous kit with a fogger nozzle. it has 2 lines going it the nozzle one for gas and other for nitrous but they are not the same length is that for a reason or should they be the same length fuel line is about 12" and the nitrous line is about 18" what do you all think.....
Old Mar 6, 2008 | 09:26 PM
RAGENZ28's Avatar
I doubt it will make a noticeable difference, if anything it would be a bit rich for a fraction of a second.
You can also shorten the one line and reflare it, problem solved
Old Mar 7, 2008 | 05:26 AM
Beer99C5's Avatar
You can get new custom length lines from any of the vendors (Dynotune, Nitrous Outlet, or HSW). Generally the shorter line would be for the fuel as that is lower pressure and will travel slower than the Nitrous.
A few of the venders have different color fittings and even different color hoses as well.
Old Mar 8, 2008 | 10:28 AM
Hrlyrdr97's Avatar
I just ran into the same thing with my new HSW kit. It's like Beer said. The nitrous line is longer to reduce the lean spike from the nitrous.
Old Mar 10, 2008 | 10:54 AM
Chris@NitroDaves
Guest
Posts: n/a
They probably did that to cut a lean spike out. You should be fine using those lines.
-Chris
Old Mar 10, 2008 | 11:16 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Actually, most kits do that because the fuel solenoid is on one side of the intake and the nitrous solenoid is on the other. One has to be longer to reach around the intake and go into the nozzle. The difference in length is negligible and will not make a difference
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
