harris speed works
Old Mar 8, 2008 | 11:41 AM
dustinLS1/LT1's Avatar
Default harris speed works
i am planning to buy a harris speedworks 90mm nitrous plate is anybody running this? it looks like it will work great ive researched alot and it is my favorite one so far.
Old Mar 8, 2008 | 12:22 PM
Hrlyrdr97's Avatar
I just installed one on my car. Haven't run it yet. I did the same as you. Looked at all of them and the HSW was the most impressive. I know Nitrous Outlet has about the same design plate.
Old Mar 8, 2008 | 03:45 PM
myfast70's Avatar
I've got one and love it! Would have no problems buying another one if I needed to.
Old Mar 9, 2008 | 12:07 AM
Sinister95Z's Avatar
I do not have a plate kit, but I do run an entire HSW brute force wet kit. You will not be disapointed with the decision to run Harris Speed Works.
Old Mar 9, 2008 | 12:22 AM
sprydncamd ta's Avatar
you wont be dissapointed if you think it is impressive on paper wait until you see it in person the quality is second to none
Old Mar 9, 2008 | 12:39 PM
Robert56's Avatar
HSW is plumbing my DP Dry system. They have great prices as well as an advanced understanding of how n2o works. You won't be disappointed.
Robert
Old Mar 14, 2008 | 09:43 AM
i cant wait im going to hit it with a 150 shot. i just hope to be midish low 7's in the 1/8th ind mid 11's in the 1/4 that sound reasonable?
Old Mar 14, 2008 | 09:48 AM
Mike@HSW's Avatar
a 150 shot should put you into the 11's easily. do you have a stock 10 bolt? with slicks i wouldnt spray right off the line. Even if you lock out 1st gear it should still be enough to get you there.
Old Mar 14, 2008 | 10:34 AM
i have a stock 10 bolt with an auburn locker and gears. i have 26/11.5 15's hoosier quick time slicks.
