Fuel pressure safety switch question
Old Mar 9, 2008 | 11:49 AM
AR15 guy's Avatar
Default Fuel pressure safety switch question
For an lt1 car which PSI switch do I need? the 30psi or 50psi?
Would you guys also recommend running a filter before the nitrous noid?
And should I run my main nitrous line inside the car or under the outside.
Old Mar 9, 2008 | 12:07 PM
madclown's Avatar
I think the FPSS are set at around 35psi for fuel injected vehicles but are adjustable. I have my N2O filter between the bottle and the feed line and the feed line is run outside the car. Hope this helps.....
