Arming switch
Old Mar 9, 2008 | 07:53 PM
briangto2004's Avatar
Default Arming switch
I was about to get my tune and everything looked good but when I turned on the ARM switch the nitrous hit could this be from a bad WOT switch? What could this Be?!
or the window switch I have the LS1 timing tuner/n2o controller does anyone have this kind of window switch?
PLEASE HELP!
Old Mar 9, 2008 | 08:01 PM
GT Griller's Avatar
is ur WOT switch the one with 2 prongs or 3?
Old Mar 9, 2008 | 08:08 PM
it has the 3 prongs
Old Mar 9, 2008 | 08:21 PM
GT Griller's Avatar
If i remember correctly if u connect the 2 prongs furthest apart then ur N2O will be spraying all the time unless the WOT switch is pressed.....so u need to connect the prong that comes out from the side and the middle one....that way it will be N2O only sprays when the WOT switch is pressed.
Old Mar 9, 2008 | 08:37 PM
Yeah im pretty sure I have it like that
Ill go take a picture and post it
thanks
Old Mar 9, 2008 | 08:47 PM
Heres the pics of how I got it set up looks correct to me?
could the little switch be stuck?
Old Mar 9, 2008 | 08:48 PM
By the way the zip tie is not effecting the button on the switch
Old Mar 9, 2008 | 09:44 PM
GT Griller's Avatar
hmmm the little lever looks really close to the pedal.....the pedal should only touch it when u floor it......it looks like any kind of pressure on the throttle and its gonna push it.
Old Mar 9, 2008 | 09:48 PM
no I checked and it is not engaged the metal piece doesnt even touch the button underneath the metal piece. I have a throttle body bracket and WOT switch so ill be replacing it will go from there
thanks
Old Mar 9, 2008 | 09:50 PM
GT Griller's Avatar
In that pic right there it looks like as soon as u give it a lil bit of gas the switch is gonna be activated.
