Got my kit installed!!
Let me know what you think!
I know the fuel line looks tight but theres a good 3+ inches of play.
also installed my trans temp gauage.
Plans for down the road.
1. longer fuel feed.
2. plate upgrade
3. wide band w/ lean shutoff.
Yeah I love the look of the plates.
I will be getting one eventually.
I will most likley redo everything over next winter, but this should get me going. Track opens april first here!
Nice... I was going to ask you how it performs. but, I guess you have not tried it yet. The track for us dont open up till May! :-(
I just bought the NANO system, timing tuner (exactly like yours) and an auto bottle opener.
briangto I can't say how I like the timing tunner yet because its just set to stock for now.
I can say it was pretty easy to install after removing the starter. I will let you know once I actually use it
. The Best V8 Stories One Small Block at Time
[IMG]http://i188.photobucket.com/albums/z164/waterbug1999/croppedrails.jpg
I am looking at getting a braided to bulkhead.
I'm just not ready to drill a big hole in the car.
i might try to route the hard tube through the seat delete.
I go to irp/orp in Indy tech has never poped my hood so they might not check.
Robert
I don't think there will be to bad of a lean spike. If you are refering to the feed line causing it. The fuel is already to the noid everytime the key is on.
I know the lines form the noid to the nozzle are the same length but, I think the lean spike will be minimal at best.
I am a noob so I could be wrong, but from what I have read and talked to freinds about, I think I should be ok.
