383-402-408/N2O times
Old Mar 24, 2008 | 03:21 PM
Big Geek's Avatar
Default 383-402-408/N2O times
I was curious as to what some of ya'll with 383/402/408 and N2O were running. I have done quite a few searches and it would seem that most of the info that I find is related to dyno numbers which I am not all that interested in. So if you have one of the above and would like to post up please do so. Please include your 1/8th and 1/4 mile times and speed as well as how much N20 and the type of tranny and rear gearing. In short -
Displacement (383,402 or 408) =
1/8th mile time and speed =
1/4 mile time and speed =
How much N20 =
Plate, nozzle or direct port =
Cam, heads and compression =
Tranny type (Convertor size and type if applicable) =
Rear gearing & tire size =
Anything else you may feel important. Thank you in advance and I hope this will help those that may search for this info in the future.
Jim C.
Old Mar 24, 2008 | 04:59 PM
Noyzee's Avatar
8 second mod
my 402 acouple years ago 3600 pound are, 28" tire, power glide with 3:73's 1 stage 200 went 9.3 300 or 350, i forget now went 9.0 at 147 forget 1/8
timmys car with 383, 2 stages 400 total went 8.9 153 i think, with 200 it runs 9.3-9.4 all the time, he is about 3200 pounds, same gear/tire
Old Mar 24, 2008 | 06:49 PM
98Z28CobraKiller's Avatar
Restricted User
I have a thread going right now and am posting in another with regards to calculating actual nitrous volume used. One guys "200 shot" may make 200 at the wheels because he is running the jets at 900 psi while another guys "200 shot" could be putting closer to 300 to the wheels because they are running it at 1300 psi. So it makes discussions like these kinda useless without including the pressure that said kit is running at.
Take me for instance. I was spraying a "400 shot" thru a -4 line (does not support over 300hp shot) at 1000 psi and ran a 9.52 @ 142 with a race weight of about 3700 lbs. This adds up to useless information for you as I really wasnt getting 400 to the tires.
Old Mar 24, 2008 | 08:30 PM
caliswangin916's Avatar
from all my reading...higher shots will yield slightly less than their rating but within reason.
i would not want my 200 jets to spray a 300 shot. if i want a 300 shot, i'll put in 300 jets. a 200 shot giving almost 300hp is crazy given that both are rated at the wheels or both are rated at the engine.
Old Mar 24, 2008 | 08:55 PM
Restricted User
My point is that the jetting is only one factor in determining how much power it will yield yet is what people refer too as their "shot".
Old Mar 25, 2008 | 07:49 AM
Big Geek's Avatar
I understand what you are trying to say and appreciate your input. I have been playing with N2O for a little while now and am trying to compile a "jest" of data. Not so much in detail but more-so an average. I hope you understand. Thank you for posting up though.
Jim C.
Old Mar 25, 2008 | 07:52 AM
Big Geek's Avatar
OK Gents, I would like to get this back on track. There are many factors besides bottle pressure and line volume that determine the amount of N2O used. How do I know this; more than 20 years of playing with N2O but I don't want to turn this into that type of discussion. What I want is posted above, that is all. Thank you for posting up but lets get this back on track or just close it up. Thanks again.
Jim C.
Old Mar 25, 2008 | 08:04 AM
Noyzee's Avatar
8 second mod
my tune ups are all at 1000-1050 bottle pressure and around 6-8 psi on the fuel side depending on tune up, weather etc
Old Mar 25, 2008 | 01:23 PM
ls2formula's Avatar
Have you had your car on the rollers to see what kind of gains you get with your 200 shot?
Old Mar 25, 2008 | 06:06 PM
GueSS Who's Avatar
I spray 500 pills at my 410ci iron motor. Check out the sig
Old Mar 26, 2008 | 07:47 AM
Noyzee's Avatar
8 second mod
my car hasnt seen a dyno with the new motor. with my 346 back in the day the car made just a hair under 400 rwhp with a "300" shot 1050 botle press it made 703. this was once i found the right cam and tune up.
the other cams i was using to test i wasnt make 300 with the same tune ups. i was making in the 260 range. my ESP N2O cam worked real well in my 346. picked up big power and droped about 2-3 tenths
Old Mar 26, 2008 | 09:33 AM
Restricted User
I recently swapped my cam and I feel that it really helped alot on the juice. I was hoping to confirm it at a track rental in Bradenton (DH7) but we got rained out.
Old Mar 26, 2008 | 09:53 AM
Noyzee's Avatar
8 second mod
im heading to fla 1st or 2nd weekend in may. anything going on?
i'll be on anna maria island near bradinton
Old Mar 26, 2008 | 02:14 PM
Restricted User
Make up date for our rain out
DEAD HOOKERS 7 MAKE UP DATE
NEED2SPEED.COM SLICK TIRE AND DRAG RADIAL ONLY PRIVATE TRACK RENTAL !
Sponsored by RevXtreme
Saturday, May 10th 4:00 p.m. - 10:00 p.m.
Bradenton Motorsport Park
Old Mar 26, 2008 | 02:48 PM
Noyzee's Avatar
8 second mod
hell yea, once i book my tickets i'll see what weekend it is. if its that one, i will shoot up there
Old Mar 26, 2008 | 06:24 PM
Restricted User
I'll be there for sure. My name on that site, youtube, streetfire and everywhere else is LOSLS2. Send me a PM if you can make it and I will introduce you to some people in real life that you may have already met thru here.
Old Mar 26, 2008 | 07:05 PM
WHITE DEVIL's Avatar
mine has the 225 pills @ 1000psi in it, motor specs is in sig, with tranny and gear. gained 32xhp to the tires on that shot made 743 and 662
1/8 - 6.2@112 in and out of the throttle
1/4 - 9.74@143 same pass in and out
Old Mar 27, 2008 | 08:04 AM
Restricted User
Why in and out of the throttle?
Old Mar 27, 2008 | 11:21 AM
JL ws-6's Avatar
Race your car!
402 6.17 1/8th mile, 9.6 1/4 mile, 150 shot thru a Nos plate, eastside stroker cam/ ET 240 heads 13.5 to 1 compression, TH400, 5400 rpm converter, 4.10 gear/28 inch tire, 3500 lbs
Went to a 3.73 gear, lost 200 lbs for this season
Old Mar 27, 2008 | 11:37 AM
Noyzee's Avatar
8 second mod
booked last night, im going down the 1st thew the 5th so i will miss that race. anything else going on?
