main nitrous line question
Old Mar 24, 2008 | 03:50 PM
BLACK 97 SS's Avatar
Default main nitrous line question
is there a way i can run my main line without drilling a hole through the firewall? if so can i pls see pics
Old Mar 24, 2008 | 03:58 PM
porksoda's Avatar
There is a grommet behind the PCM. You will see where a bunch of wires runs through there if you pull out the PCM.
silver 2000 ss's Avatar
Default main line
Yes you can, right side of your car take the kick panal off and you will see a spot. I got a 2000 ss and that is were I ran my line.
Old Mar 24, 2008 | 04:20 PM
quickblade's Avatar
run it under the car. That would be the best suggestion.. Take it down under one of the seats.. There are rubber plugs filling 4 holes in the rear seats... 1 hole under each seat, and 1 hole on the floor board in the back... under the seats is the best way.
make the grommet fit around the line, and bam... Run from driver side rear seat, then you can run it against the fuel lines, and you are in like flynn....
the feed line will come up along the engine firewall where the fuel line goes up...
easy piesy pie...
Old Mar 25, 2008 | 01:21 AM
thanks alot guys really appreciate it
