Serious Nitrous Junkies....What cause pinging when sprayed ?
-I use 93 octane fuel
-TR6 Plugs
-100 shot wet plate kit
-On dyno, the spray initially hits hard but then seems to get weak and goes rich the higher the RPM goes
-KR was 0 across the board when tuned except for one spot where it was .3
-Cam + spray = no problem......After head install, it pings pretty violently.
Car seems to run pretty good on motor, no odd sounds, maybe just a little weak with the heads/cam setup I have but nothing really out of the ordinary. I may have covered all the options but if I didnt Ill answer any questions to the best of my ability. I really need to get this figured out.
Thanks guys
Chris
Not sure.. have not had this issue, or seen anyone post about it...
But at least its a thought.... sorry not much help from me...
only that ..... Or timing..
i always try to use some torco or 104 when i spray, its just plain cheap insurance.
im not sure wtf quickblade is talkin about. i spray 250 without my heads lifting or any gasket issuies.
you can and should take a degree or two of timing out if you can, but the .3 knock isnt anything to sweat in my opinion. 3.0 is btw, especially if your using unleaded race gas
Jim C.
Jim C.
timing is 21* full advance. I do have an update....I just drove it and it runs like ****. It has almost no power and stumbles through the RPM range
Jim C.
ahhhh.. but the gas talk.. LOL
dam dont know what I was talking about the other day.
Now that I think about it, it probably is the gas. When I spray on crappy gas, it pings and is not good. Need to find some good gas.
I think its more of an issue with the motor of valves becuase I drove it today and it has NO power, stumbles through the RPM range, and even statred backfiring. Probably going to pull the heads tonight
Question: Could haveing a bent valve cause pinging when I spray?
Decided to do another leakdown on 5 and 7 cylinders since it seemed to get worse today while I was driving it.
5 was 10% leakage but 7 was 30% leakage and clearly was coming from the oil cap and dip stick tube. I then proceded to squirt oil in the cylinder and it fell to 13%
New motor time
