Installation of fogger system on an LSX with carb
Old Mar 29, 2008 | 07:25 PM
NOS4EVER's Avatar
Default Installation of fogger system on an LSX with carb
Step by step installation of a fogger setup on our race car
With a big thanks to Texas speed & performance
1-Starting with the intake manifold drilled for the foggers
2-Using a thread sealant on all foggers
3-All 8 foggers installed making sure that all of them are parallel
4-Install all the tubes to check for clearance of the blocks and solenoids to the carb Linkage
5-For ports # 3,4,5 and 6 bend the tubes closest as possible with a 90 deg
for the fuel tubes
6-For ports # 1,2,7 and 8 bend the tubes a bit longer to align with the top holes on the blocks
7-Place the block in between the # 3 and 5 port and mark where the ends of the block
8-Using a tube cuter cut little further than the line you marked to have some clearance for the fittings
Old Mar 29, 2008 | 07:29 PM
NOS4EVER's Avatar
9-Connect the inner tubes then install the fittings
Excuse me for the clean hands
10- For the NOS tubes are a bit tricky since they will have 2 bends one is almost 30 deg and a 90 deg
First I marked the area which with be parallel with the fuel block and then bend the #
3 and 5 30 deg.
The hardest part is holding the solenoid + block + tube with one hand and taking a
Photo with the other lool
11-Repeat the cutting procedure
Old Mar 29, 2008 | 07:32 PM
NOS4EVER's Avatar
12- Finished at last with all tubes aligned
13-Fitted on the car
Opps wrong 1
14-The 440ci and the bird
thanks
Old Mar 29, 2008 | 09:07 PM
stevied916's Avatar
nice work! That things gonna scream
Old Mar 30, 2008 | 12:54 AM
Nacho SS's Avatar
Wow, nice work!
Old Mar 30, 2008 | 03:53 AM
NOS4EVER's Avatar
Thanks
Old Mar 30, 2008 | 01:43 PM
ATwelveSec02Z28's Avatar
Looks killer - is that the GMPP or Edelbrock intake?
Old Mar 30, 2008 | 02:22 PM
NOS4EVER's Avatar
its the GMPP
