How much N2O?????
Old Apr 1, 2008 | 12:19 PM
QucikSilver's Avatar
Default How much N2O?????
I want to know what is a safe shot for this motor. Mahle 3.905 forged pistons, Scat H-Beams forged rods, stock crank, all ARP, and balanced. The shop said these are not nitrous pistons or rings but I keep getting different opinions. The shop that built it said no more than a 150 but others say 250 is fine.
What are your opinions???
Old Apr 1, 2008 | 01:09 PM
jmill96Z's Avatar
I'm pretty sure I have the same pistons. Are they -4cc's? I've sprayed a 200 through my car with plans to run a dual stage 300 this year if that helps any.
Old Apr 1, 2008 | 02:43 PM
That is what I was thinking but the shop that built the motor told me that it didn't have nitrous rings on them and that they weren't nitrous pistons. Have you heard such a thing?
Old Apr 1, 2008 | 03:29 PM
00cls1camaross's Avatar
There are such things as nitrous pistons.
Old Apr 2, 2008 | 02:57 AM
Do you know if the Mahle -4cc pistons are a nitrous safe (big shot) piston (200+ shot)?
Old Apr 2, 2008 | 09:10 AM
jmill96Z's Avatar
I wouldn't sweat it. I'll let you know in a month and 10 days how they handle a big shot.
Old Apr 2, 2008 | 10:27 AM
Honestly a 200 is probably all i will need. That with a MS3. The highest is going to be 250. As long as it is a badass nitrous tune. You think it would be wise to run a 1 gallon cell with race gas for that.
Old Apr 2, 2008 | 11:20 AM
jmill96Z's Avatar
I like 150 off the rail, but I am going to a cell for the bigger shot this year.
Old Apr 2, 2008 | 11:44 PM
200 is about where race gas comes into play correct. I was also told to go LS6 intake rather than FAST. I was also contemplating the BBK. Any thoughts?
Old Apr 3, 2008 | 01:01 AM
jmill96Z's Avatar
I run the LS6 because I'm cheap. I would jump on a ported FAST in a minute if I didn't have a million things going on.
Old Apr 3, 2008 | 01:25 PM
I was told that due to the FAST being a three piece intake that in the event of a nitrous backfire it would blow the intake apart. Aside from that would a LS6 get the job done on a 200 for now?
Old Apr 3, 2008 | 01:31 PM
jmill96Z's Avatar
A blowout will destroy any plastic manifold. It just hurts a little more when that intake costs a grand.
The FAST will let you run higher RPM before it runs out of breath.
Towards the end of last year I felt like the LS6 was turning into a bottleneck for the 200 shot. I am keeping my LS6 just out of need though.
Old Apr 3, 2008 | 02:29 PM
19trans_am98's Avatar
what would be the max shot on a 4.8 truck motor?
Old Apr 3, 2008 | 03:04 PM
need to know b4 tomorrow bc im taking it to the track
Old Apr 3, 2008 | 03:18 PM
I have seen a friend of mine safely run a fat 125 through it but I would say 150 with some octane booster should be fine.
Old Apr 3, 2008 | 03:25 PM
jmill96Z's Avatar
Start low and work your way up. You need to pay attention to your plugs as you work your way up though.
Old Apr 3, 2008 | 03:27 PM
00pooterSS's Avatar
oh noes
"shakes head"
Old Apr 3, 2008 | 03:47 PM
What's wrong with the octane booster. I ran race gas every once in a while but the VP booster or the NOS booster seemed to do the trick.
Old Apr 3, 2008 | 05:02 PM
jmill96Z's Avatar
No, don't use that stuff. Torco works really well if you don't want to mess with race gas
Old Apr 4, 2008 | 01:41 AM
Will Torco be good for the 200-250 range of should I go ahead and use race gas?
