Nitrous Bottle Placement
Old Apr 8, 2008 | 03:48 PM
LS-ONE_DAY's Avatar
Default Nitrous Bottle Placement
A friend of mine with a 2002 Camaro Z28 was thinking of getting nitrous for his car but isn't sure where he would be able to put the bottle, so where is the recommended place to put a nitrous bottle on 98-02 Camaros?
He has T-Tops in case that matters.
Old Apr 8, 2008 | 03:55 PM
C_Rules's Avatar
spare tire well (for a stealth setup) or the hump between the rear seats. these are probably the most popular for camaros.
Old Apr 8, 2008 | 06:17 PM
1969mach1's Avatar
to mount on the tranny hump you have to fab a custom mount.
to mount on top of the rear deck you must drop the gas tank.
to mount in the spare-tire area you lose the spare.
I have t-tops so mounting in the rear trunk was out.
So, here is where mine went.
Old Apr 9, 2008 | 07:37 AM
LS-ONE_DAY's Avatar
How hard is it to fab up mounts for the rear seat hump?
For putting it in the spare tire location is there enough room to mount the bottle at the correct angle or whatever? I heard that there is a certain way the bottle has to be placed.
Old Apr 9, 2008 | 08:02 AM
1969mach1's Avatar
you'll need to fab some mounts for the spare-tire area as well.
To fab up mounts is not hard if you have the tools (lathe, roller, welder, ect...). You could build a templet out of cardboard and take to any fab-shop and they can fab one up for a fee.
As far as mounting the bottle, you don't want it facing backwards or upside-down.
Old Apr 9, 2008 | 08:11 AM
Ruckus46Gt's Avatar
spare tire with 860 mount
Old Apr 9, 2008 | 09:14 AM
DopdBrd's Avatar
I have a custom mount that is similar to the 860 mount for sale if you are interested. PM me.
Old Apr 9, 2008 | 09:26 AM
Z-RATED94's Avatar
No fabbing required for the tunnel mount. Just hit up Nitrous Outlet for one.
Old Apr 9, 2008 | 10:30 AM
LS-ONE_DAY's Avatar
Noob question...which is the tunnel mount that needs no fabbing?
Old Apr 9, 2008 | 10:55 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Transmission Tunnel Mount
http://www.nitrousoutlet.com/catalog...product_id=984
Spare Tire Area Mount
http://www.nitrousoutlet.com/catalog...product_id=963
edit: fixed links
Old Apr 9, 2008 | 11:21 AM
LS-ONE_DAY's Avatar
The two links you posted up are the same fyi. Thanks for them though.
I found this picture on FQuick http://www.fquick.com/garages/viewga...viewimg&id=751
He mounted the bottle between the rear seats but it doesnt look like he used that bracket.
Old Apr 9, 2008 | 12:11 PM
C_Rules's Avatar
someone needs to fab up a bracket that works with the nano in the spare tire well. not sure if the current ones would work with a nano unit.
Old May 8, 2008 | 09:53 AM
onebad636's Avatar
How do you get the T-tops in there? Also on my old Z I put a peice of plywood under the carpet and didn't have to drop the gas tank. The nitrous bottles mounted directly to it.
Me and a buddy mounted his on the rear hump and used some 1/4" strap metal and bent some metal straps and mounted his bottle brackets to them. Looks clean as hell.
Old May 8, 2008 | 10:50 AM
got_r_done's Avatar
If you use that bracket to mount the bottle between the seats, does it use existing bolt holes (like the seatbelt bolt holes), or do you drill your own? When my brother was 16, he put a ZEX kit on his Prelude, and he drilled 6 holes in the gas tank in the process. We went driving around the next day, and I was like, "dude, you smell gas, I'm about to pass out from it, roll the windows down," lol.
Old May 8, 2008 | 11:22 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
our tranny tunnel mount require you to drill 4 holes in the tunnel.
