HSW S-I-Kit Window options
Old Apr 9, 2008 | 09:03 PM
Dexter's Avatar
Default HSW S-I-Kit Window options
I just got my order in the other day for my sudden impact single nozzel wet kit. I ordered the kit, warmer, fuel pressure shut off, n20 pressure shut off, n20 filter, blow down kit, purge kit, ashtray plate, annnd so forth... at the end of this order was the timing tuner / air fuel adjuster which for some odd reason I thought was also a window activation switch... Of course I was very wrong... But it can however be hooked into a window switch, and after browsing the HSW site a bit more and found only what I have but on steroids for a window switch, which I can't obviously justify buying since two thirds of this new device I already own... Where else and who else sells a decently priced device whos sole purpose is to function as a window activiation switch with 1st gear lockout... I have a M6 and simply do not feel comfortable shooting with out one. Oh, and of course this switch I am in search of must be compatible with my entire layout that I have strewn about in the following pictures... Thanks in advance !!!
Attached Thumbnails HSW S-I-Kit Window options-nitrous-013.jpg   HSW S-I-Kit Window options-nitrous-015.jpg   HSW S-I-Kit Window options-nitrous-014.jpg
Old Apr 9, 2008 | 09:11 PM
Robert56's Avatar
You can use any WS you like, a cheaper one if $$ is a concern. I believe my write up on the 1st gear lock out is still in the wiring sticky, it costs about 3 dollars and i have been running it for years, and it's really only for the manual guys. I always try to be frugal with my money so i understand.
Robert
Old Apr 9, 2008 | 09:18 PM
Nitro Dave's Nitrous Outlet's Avatar
We offer a tow very popular windowswitches that may catch your eye.
Both have built in TPS activation and the any gear lock out feature. One will controll two stages and one will control one stage.
Single stage-
http://www.nitrousoutlet.com/catalog...roduct_id=2885
Dual stage
http://www.nitrousoutlet.com/catalog...product_id=964
Both are in stock and can ship the same day.
Dave
Old Apr 9, 2008 | 09:38 PM
Dexter's Avatar
Ok, I took a look at the site for the single stage window switch... Ok, looks pretty good... I wish I didn't have to spend another hundred bucks... and maybe I won't. I will call HSW and see if they can take this item I have back and send me their all in one version. At least thats less spending! Buuuut, if this is what I will have to do then I will bite the bullet and buy it. Thanks for all of the quick responses!
Old Apr 10, 2008 | 02:02 PM
Danger731's Avatar
I have a the same HSW kit with a plate. I got the BNM WS from HSW as well.
Old Apr 10, 2008 | 06:51 PM
Robert56's Avatar
He you guys, I have some very good wiring diagrams (2, not sure if both are posted, though at least one) straight from BMN on their WS. Some custom stuff and notes of my own. I had asked for this specific diagram when i was going to run one. It's on my site that you'll have to go looking for as I can't currently link to it.
Robert
